10-21-2005, 19:46 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | Please Post All Info About 6600 White Screen For that promlem last time I did all these things but the problem is same: - fully erased with Griffin and UFS - flashed with both lower and higher flash 3.42 and 5.27 - Rehot all flashes RAM, and UPP - Changed 4 flash IC - changed UPP - changed UEM - Reflashed again and again - chacked BSI line all are OK - VIO,VCORE, VANA, VFLASH1 all are OK No result! Now if there is any professional can solve this problem I think it will be revolution for me! Because I got tired! Please HELP!!! Please do not say check LCD connector or christal! This is not a display problem, phone can not turn on, just lights are lighting and then hanging, after a time lights go off! This is a boot problem I think! Regards! Last edited by KUBAT1; 10-21-2005 at 20:05. |
10-21-2005, 20:08 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | solution No1: (no pm and ppm area feeding) check if Vio is going to pin's/ball's A5,B1,D8 on flash D316.if Vio is not feeting to B1 and D8 then you can erase and write to flash but you can't read. solution No2: (boot problem) http://forum.gsmhosting.com/vbb/show...ght=6600+white this is not stable problem.it can be fault another flash,ram or upp. CAUTION:this is solutions when phone does not boot NOT IF PHONE WORK OK BUT LCD IS WHITE. |
10-21-2005, 20:24 | #3 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 104847 Status: Offline Thanks Meter: 5 | first check if handset make calls even in white screen if not then mostly this problem is due to small black ic near vbat pin i solved this in around 5 handsets of 3650 and 2 6600 sets |
02-25-2006, 02:52 | #8 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | maybe this can help! today i got a 6600 with bt problem and when saving photo i got error message, then can not open gallery, i saw here that this problem is from the bluetooth module, so i rehot the bt module, and now i got white screan and turn off after some second maybe this problem is from the bt module, isn't it? |
6600 white screen no boot (I tried all you have read) | shimano1234 | WD2 & APE (Symbian Phones) | 22 | 06-30-2011 06:09 |
How to read info or make local or test mode 6600 white screen | shimano1234 | WD2 & APE (Symbian Phones) | 1 | 06-18-2008 08:32 |
Help need 6600 white screen,contact retailer i read all the post on forum...HELP | ZetMen | Nokia Hardware & Hardware Repair | 16 | 08-30-2005 09:32 |
my 6600 white screen.. helllp | Tbaba | WD2 & APE (Symbian Phones) | 11 | 04-01-2005 18:38 |
6600 white screen! | sergioems | Sell ur Old and Used Stuff | 0 | 12-05-2004 14:31 |
