09-27-2008, 07:19 | #1 (permalink) |
Junior Member Join Date: Jun 2008
Member: 801104 Status: Offline Sonork: jeeva Thanks Meter: 0 | 7610 hung ATO: p????????????????????????????????????????????????? Default SN type: p????????????????????????????????????????????????? log is here plz help eney body Getting MCU ID MCU ID: 0x1081 FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 6.0522.0 02-06-05 RH-51 (c)NMP HW version: 7029 PCI version: UEM version: 144 UPP version: 4225 RFIC version: 0205 DSP version: CN5.10 PPM version: V 6.0522.0 02-06-05 RH-51 (c)NMP.03 BT MCM version: Production serial number: PEL390988 Product code: 0514537 Module code: 0202215 Basic production code: 0528496 Flash code: Order number: Product specific data: Long production SN: ATO: p????????????????????????????????????????????????? Default SN type: p????????????????????????????????????????????????? IMEI plain: 358390008540539 IMEI spare to net: 3A 85 93 00 80 45 50 03 IMEI SV to net: 33 85 93 00 80 45 50 33 F0 PDC: 4E 54 54 4A 50 12 34 56 Master Code: 0646017104 Phone type: RH-51, Software version: 6.0522.0, Language Pack: 03 User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0514537 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.03 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,French (Arabic) Done! |
09-27-2008, 07:28 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: VIZAG,A.P,๑۩INDIA&
Member: 733702 Status: Offline Sonork: 100.1579452 Thanks Meter: 580 | frist full erase and flash ,ok pm,unlock,factory settings,file sys format then cheak it post result |
The Following User Says Thank You to laxman kumar For This Useful Post: |
7610 nokia hung up software is okey | lilong_lee | Nokia Hardware & Hardware Repair | 4 | 08-30-2012 09:00 |
7610 hung up i try all virsion but stell same nokia afair in screen | lilong_lee | BB5KING | 16 | 08-24-2009 11:14 |
x430 hung up | didinagma | Trident/AGERE Platform | 1 | 12-05-2005 22:02 |
Mars fls with Hung lang | Blueman1 | Mitsubishi | 0 | 10-02-2002 23:25 |
