Old 01-28-2008, 09:01   #1 (permalink)
Member: 19190
Thanks Meter: 28
1110i display goes reverse side
i had flash an 1110i RH-93, after flashing , the display show reverse side, any good solution for it?
Old 01-28-2008, 09:05   #2 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
was it an indian production v6.46
Old 01-28-2008, 09:16   #3 (permalink)
Member: 285779
Thanks Meter: 49
alex ..
did u flash cnt file ?
u lcd is 1110i rh-93 ?
Old 02-02-2008, 17:38   #4 (permalink)
Member: 320858
Sonork: 100.1602961
Thanks Meter: 25
Hello brothers I have the same problem with 1110i indian phones when unlocking I get error then the phone does not power then I flash after flashing I get reverse display
To you qurstions yes I flash cnt or I full flash it.
pliz assist.
[email protected]
Old 02-02-2008, 20:17   #5 (permalink)
Member: 262039
Thanks Meter: 7
make full flash mcu+pm+cnt with latest version 7.02
Old 02-02-2008, 21:43   #6 (permalink)
ami236's Avatar
Member: 64602
Thanks Meter: 4
Yes problem is CNT , and for sure The phone is India Made . You can solve this problem by changing LCD and you can return phone to customer. I think no solution only this.
Old 02-04-2008, 02:40   #7 (permalink)
Member: 19190
Thanks Meter: 28
finally i have flash to v6.93, then now the phone is normal back, thnx for all...!!!
Old 02-18-2008, 14:41   #8 (permalink)
AlgMUR's Avatar
Member: 72109
Thanks Meter: 22
hello all
i have the same problem, iflash my phone with sarabox, version 6.46 and it work fine now.
remarque:
for the indian mobile phone we can not change the version of the firmeware, only we have reflash it with the originel flash, because indian phone have a diferent Uem. And the unlock solution there is no yet.
thanks and good luck
Old 02-18-2008, 17:59   #9 (permalink)
fundisimu's Avatar
Member: 585028
Thanks Meter: 25
flash the phone using latest version (6.93) it will be okze
Old 02-18-2008, 18:17   #10 (permalink)
Member: 659474
Thanks Meter: 20
hi brt ...use this in mcu
6288 Display problem UP Side Down Image Fatmox Nokia Hardware & Hardware Repair 10 10-15-2009 17:25
6085 camera module not ready and mini display vieaw's reverse graphic solution badboysssss Nokia Hardware & Hardware Repair 0 01-30-2009 11:40
E398 Display Ok But Everythg On Reverse Side! Need Help?? khem Motorola Hardware Repair 1 08-13-2007 10:57
v3690 display goes off after closing and opening case noone0 Motorola Hardware Repair 3 01-05-2005 01:54
sl45i switch off every time the display goes dark invisible_PL x1x to x45/x50 1 07-27-2003 02:12
Page generated in 0.16948 seconds with 10 queries
