03-18-2004, 16:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Scandinavia
Member: 42160 Status: Offline Thanks Meter: 0 | PLS help with strange 3310!?!?!? IŽam having a little hard time with one pcs of 3310> updatet to 3315. However suddenly the phone wont power on anymore! I can flash the phone without problem & also charge the phone...all working good! Only thing is that i canŽt turn phone on with batteri inside! Also i can NOT turn phone off/on with cable connected as with other 3310... I have tried to change power button with no real joy! Anyone have an answer for this one? Many Thanks in advance.... Regards |
03-18-2004, 17:20 | #2 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 22208 Status: Offline Thanks Meter: 9 | if your sure the 3310 was working before it will work again. maybe your eeporom is bad. Just flash with a full 2mb 3310 flash and then update to 3315 using pc local or any other tool. then reset UI etc. you'll be ok. good luck |
03-18-2004, 18:29 | #3 (permalink) |
Member: 42160 Status: Offline Thanks Meter: 0 | I think this is NOT software related! Have tried to flash phone few times and that is no problem! Only power up/off the phone does not work! Even not with flasher cable connected!! |
03-20-2004, 15:54 | #4 (permalink) |
Member: 22208 Status: Offline Thanks Meter: 9 | downgrade the phone. maybe the flash your using doesnt work with the hardware in the phone. another thing is are you sure you didnt make any mistake when flashing the phone for the first time? There was a time i flashed 3330 software into a 3310. it didnt work with ALL other 3310 soft until i downloaded 3310 soft from a working phone with 4mb size then loaded it into the dead 3310. Good luck |
pls pls help with radio code | terry3 | CAR Electronics | 1 | 03-11-2009 08:30 |
Samsung T639 Not supported with NS, pls help with unlocking? | Boshko_Alfa | NSPRO | 24 | 02-28-2008 11:37 |
pls help with my smart clip its dead pls hep sir | andrew14 | Smart-Clip | 3 | 01-05-2006 03:03 |
Pls help with 311 on and off with simcard in it | ossada | BF, BG, TH, BHx Series | 3 | 07-19-2005 09:42 |
pls help with strange M35 | Salami1_1 | x1x to x45/x50 | 4 | 12-28-2001 18:35 |
