plz help me 6600 i have 6600 flash with tiwster some time flash Completed,but work 3,4 hour ok after display blank keypadlight gose on . when batt remove & on the set same problem display blank keypadlight gose on & off after some time. when i flash the set with tiwster mcu flash ok in ppm writing Process Failed. i try with jaf also Process Failed after try 4 ,5 time flash Completed &work fine some time. 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001277E,Amd 29BDS064J Fl1: 0x02000000-0x027FFFFF,0001277E,Amd 29BDS064J Fl2: 0x04000000-0x047FFFFF,0001277E,Amd 29BDS064J Fl3: 0x06000000-0x067FFFFF,0001277E,Amd 29BDS064J Algorithm: w3_amd.fia, w3_cbusb.fia Algorithm Ok, MSID: 84F96DA76615572C471E3B2B03 Decoded MSID: 3E4EBAF7-00584A6A-A9000000 Encoded FAID: 87AC47AA-361403A0-3C6F7F67 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x007FFFFF Erased, Time: 01:03 Area3: 0x04000000-0x046FFFFF Erased, Time: 00:53 Area4: 0x06000000-0x066FFFFF Erased, Time: 00:52 Area5: 0x047C0000-0x047EFFFF Erased, Time: 00:01 BT MCM (21) Image Found: 0x0002DD94 BT MCM Registering Done MCU Flashing Completed, Time: 04:33 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x02000000-0x0213FFFF Erased, Time: 00:05 Write Error: hDat 14, at: 0x02010000:08 Process Failed, Repowering Mobile |
this seems to be a hardware problem.. maybe there are some unsoldered points under flash chip... try to rehot the PCB with care... |
re hot upp with care............................ |
i have the same i rehot upp flash but still but after change battrey conector and change ram phone is ok |
