power problem hi guys,so far i am happy to be in dis family.i have creat a file 4 myself.d most funny part of all is that i read all articles which are very educative and funny d way u open ur to each question(s).but guys what i want realy now is a bit collective information.now let say that a have 3310.it does not power.d frist i do,i frist check d volt of d battery,if it is ok.let asume that is ok.i now connect d charger to see if ther is current going to d battery,if it is ok.i now dis amantle d phone.i place d board on d jig and connect power supply 3.6v.with my multimeter check d flow of current to resistorR224 which should be 3.2v.now let assume that R224 does not 3.2v.d book that i have say that power ic is bad.in such case what do i do.secondlylet assume that R224 have 3.2v to supply power to CCONT,but VBB,VCORE does not have 2v.but VXO,PURX have 2.8v.in suc a case i do i do.some of mention to use some equipmet,some said i need net mointor,(i dont have it and i dont know what it is use 4).some mention i shld use kaljevic software(i dont have it and how do i get it) and so much more.d bottom line is,what kind of equipment do i need.i have power supply DC,multimeter,3310jig,2-1 hotair station,ultrasonic cleaner.PC with net champhion 4 unlocking/flashing.i need a coprenshive solution to my problem.and pls if any of u can assist wiht visual (cd) on replacing/reballing of bga ics.thanks(collective contribution. |
Repair flowchart! Hello friends! This is a VERY good and informative topic if carried forward... Lets add info to this thread! My contribution, Check for 2.8 volts on r224. When u press power switch, it should go to 3.2 volts. If no voltage thenm power ic (ccont) is faulty...now from here onwards, even I am at a loss... Maybe reflow ccont? and check voltage again? also, check continuity between r224 and r 402. Also, it has something to do with v414 and v202 Please keep this thread alive! Reagrds Raja3333 |
in 3310 power problem is mostly form ccont and it's work 50% by rehoting it first of like mr raja3333 says chek volteg on on/off switch without pressing butten there are2.8 and after pressing butten there is 3.2 volts on it if not reflow ccont it wll work if not u must change it than u must reflash it if not going on then chek 26mhz crystal if nothing chang 32mhz crystal if nothin remove pa and chek it to power on and u must chek them too r224 and r 402.v414 and v202 and 1 resistant near on off switch in black color ******************Azam************** |
@ azampk Hello friend, Can you guide me how to check the 26 mhz and 32 mhz crystal? I dont have a spectrum analyzer or an oscilloscope. Can it be measured with a digital multimeter ? also, can you guide me....how much will an oscilloscope that can test mobile phones cost? Regards, Raja3333 |
