Problem with 3310. Freeze & restart I have a problem with 3310. Sometimes it work OK, but when I press 1, 4 or Menu it restart or freeze. Please help. Thanks in advance. |
try cleaning board contacts or replace power switch mate :) |
Tray to change software. |
I change soft, but no luck. No SW is 5.57. Was 4.45 |
Re: Problem with 3310. Freeze & restart Barvik,, How about you will try without SIM CARD and press 1 4 7 * ??? check also at TXCO cold solder ! Willy Quote:
rehot flash and ram IC |
Hi barvik try to solder the L511 then reset factory setting with nokia tool, goodluck Wesam |
Wesam, I am sorry,, but when you said--> solder L511,, your mean, that L511 is dead ,, need to replace , or it was cold solder ? Willy Quote:
Dear willy,barvik sorry for my english I mean to remove L511 then reset factory setting without it , plieve me it sucssisful with me on many phone, goodluck Wesam |
With removing L511 nothing changes. |
dear willy what is your idea in this case? Don't you think barvik can remove and solve the problem with flashing the phone? |
Hello Light, Thanks, like membar barvik said : " have a problem with 3310. Sometimes it work OK, but when I press 1, 4 or Menu it restart or freeze" sound look like phone were hung, that is reason why, i ask barvik,, if this phone does not put any sim card,, what happen is it ? When it become "some time".... 1: Flash ROM or RAM and MCU had cold solder or rusty on pad. 2: CCONT 32.768K sleep clock not good working 3: 26/13 Mhz path open circuit, or level too low 4: battery connector no good : BSI in to CCONT, identify wrong battery type for wrong phone running mode 5: MCU to Hager control , lost timing via SCLK and SDATA , and can not read hager temperature and reset it ! 6 7 8 ,,,,,,, there is too many reason will be . but here i am talking,, "as if " phone SW have no problem ! Regard Willy Quote:
I have also same problem with 3310, it freeze and restart's. There is no diference if I put SIM inside or without it. Same problem remain's. Phone work without restarting registered to network ok, but when I tray to insert menu or make a call, phone freeze and restart. Any idea??? B.R GeniuSShadoW |
dont waste your time ! change cobba ........... |
cobba? R U crazy? all what says Willy is right, first of all rehot flash and ram ( or reball - clear oxidation under it) . than check ( change) all clocks in phone, than change ccont and hagar. ....hagar only divide 26Mhz to 13Mhz, i think this dont help, but try it.... it is strange that phone freezes only when press menu or 1,4....If phone freezes with pressing 7 too, it isn so hard to repair....but only menu, 1,4 ....strange...strange... Wolf. |
