10-10-2006, 11:17 | #1 (permalink) |
Junior Member Join Date: Jan 2006
Member: 219961 Status: Offline Thanks Meter: 0 | Proffessional Help Required every time it turn on the phone must be turn off itself after about 30 seconds... I have tried to flash succeed but always still the same.. this time even new trouble phone startup failed contact the retailer... If my diagnose is right, 1. it maybe been coz by imei ?????? (but how can it be imei ??? i don't do anything with my phone?)... 2. after connecting to my flasher UFS, Griffin or MT box, the phone should be always display NOKIA .. right??? but mine is not always.. after 30 seconds it turn off (same aswhen put the battery and turn it on. off after 30 seconds too).if still display NOKIA i can go to local, test mode.. but when NOKIA dissappears (like turn off when using batt) all mode can''t be entered..) Anyway Flash MCU and PPM and Bluetooth no problem.. Erase each address MCU and PPM also no problem.. I think it is Components fault... not ic???? I just want to be proffessional Fix my phone so i need only Proffessional GUIDE to give me advice..before i try my way.. Thanks all before and after. REGARDS, PAUL |
10-10-2006, 12:18 | #2 (permalink) |
Junior Member Join Date: Oct 2006
Member: 362419 Status: Offline Thanks Meter: 0 | Hello Dear, the phone have a bad UEM, you need replace them, after the change UEM make .ASK file with your IMEI and connect to GriffinServer to calculate .RPL file, and write it to your phone. Best Regards. |
11-01-2006, 15:59 | #5 (permalink) |
Member: 219961 Status: Offline Thanks Meter: 0 | Hi Everyone Sorry for late answer.. just repair my computer.. Cost more money.. about my posting..That's the problem.. The UEM is Glue ... i don' have confidence to replace it... so scare make the board damage....Hae any save way? or hint? Thanks paul |
Can Anyone At All Help, ***MODERATORS AND CODE BREAKERS***** HELP REQUIRED (MEGANE) | pazza198 | CAR Electronics | 3 | 04-06-2007 20:06 |
Can Anyone At All Help, ***MODERATORS AND CODE BREAKERS***** HELP REQUIRED (MEGANE) | pazza198 | CAR Electronics | 0 | 03-14-2007 17:48 |
PLZ.. HELP.. Desperate help required!! | /\/aB$ | Nokia Multimedia | 1 | 02-27-2004 05:45 |
Dismantling T28 - Help Required. | max8108 | Old Ericsson Phones & Sony Phones | 1 | 06-04-2001 19:51 |
CHANGING CIRCUIT FILM IN MOTOROLA V.3688 - HELP REQUIRED | max8108 | Motorola Old Legacy (EMMI) | 0 | 05-17-2001 21:06 |
