01-27-2010, 09:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Repair Dead Or Not Booting Ufs Here.. Repair Dead Or Not Booting Ufs Here.. YOU NEED 3 PRODUCT TO REPAIR DEAD OR NOT BOOTING UFS .... (1)MPROG FOR WRITING EEPROM (2)UFS MAINTENANCE V20 (3)UPDATE AND FIXER CONECT UFS AND ITS ASK YOU DRIVER IF NOT ASKING DRIVER SO ITS SHOW YOU UNKNOWED DEVICE OR USB TO SERIAL DEVICE...JUST FORCE HIM TO ACCEPT DRIVER IN MPROG DRIVER FOLDER.......BECUSE IT CAN CONVERT IT TO FTDI... NOW SEARCH IT IN MPROG NOW ITS SHOW YOU ONE PROGRAMED DEVICE FOUND=1 NOW WRITE EEPROM THAT I UPLOADED... AFTER IT EXIT IN MPROG....... NOW OPEN UPDATE & FIXER........ CONNECT IT AND ENTER YOUR ORIGINAL SERIAL.... TICK ON WRITE FIRMWARE AND WRITE EEPROM AND CLICK ON FIX & UPDATE..... IN FEW SECONDS....YOU DONE....... REMOVE UFS CABLE AND INSERT IT AGAIN....... DONE........UFS IS ALIVE....... IF SERIAL NUMBER IS NOT COMING THEN USE UFS MAINTENANCE V20 TO BUILD SERIAL NUMBER..... AND DO SAME PROCESS...... ALL OK TESTED 100% POST RESULT IF YOU HAVE ANY PROBLEM........ FOR MPROG http://www.ftdichip.com/Resources/Ut...g230_Setup.zip UFS_Maintenance_v20.zip http://www.mytempdir.com/292162 UPDATE AND FIXER http://www.mytempdir.com/290928 ufs_good.ept http://www.mytempdir.com/292186 Index of /stanner_austin/UFS REPAIR |
The Following User Says Thank You to Dooha_Bd For This Useful Post: |
Repair Dead Or Not Booting Ufs Here.. | stanner_austin | UFS2 + UFS3-Tornadoflasher | 619 | 02-28-2015 09:19 |
Repair Dead Or Not Booting Ufs Here | akram855 | Nokia Hardware & Hardware Repair | 1 | 12-05-2009 22:02 |
Dead or Not Dead Pkey after JAfsupport crack V106 or v108, v109 post here | TDKI | BB5KING for (BB5BOX) | 3 | 12-07-2008 09:52 |
Repair Dead Or Not Booting Ufs Hear... | stanner_austin | GSM Mobile Links | 0 | 12-01-2005 09:01 |
