Old 02-13-2009, 11:36   #1 (permalink)
Member: 856059
Thanks Meter: 124
Smile Nokia n70 white display pro
HY GUYS
i have an 70 display pro his out going and in coming is ok and i change display but its show same i change his lcd ic but same i try search in forum but i did not find any one give new sol
(plz help, thanks in advance)
The Following User Says Thank You to Hitesh manocha For This Useful Post:
Old 02-13-2009, 11:46   #2 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
@Mr Hitu
Just check with new Lcd.
W.b.r
Karan
Old 02-13-2009, 11:50   #3 (permalink)
gm33223322's Avatar
Member: 233686
Thanks Meter: 50
i think ur problem still in ic display......make sure 1st u change it propelly...
Old 02-13-2009, 11:53   #4 (permalink)
Member: 241452
Thanks Meter: 36
i have the same pro and i have try all solution found in forum no luck we need new solution pro where are U need UR HEEEEEEEEEEEEEEEEEEEEEEEEEEEEELP
Old 02-13-2009, 12:14   #5 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Smile N-70 display ways
First check all these tracks as shown in fig. maybe one of them fauilty
Karan
The Following User Says Thank You to KK Mobile For This Useful Post:
Old 02-13-2009, 12:15   #6 (permalink)
Member: 856059
Thanks Meter: 124
Smile
Originally Posted by KK Mobile View Post
@Mr Hitu
W.b.r
Karan
thanks for replay sir but i try to change display also but its show same sir i check these all track is ok its show same
Old 02-13-2009, 12:29   #7 (permalink)
fretburner's Avatar
Member: 45571
Thanks Meter: 45
Change the two display ic
Old 02-13-2009, 12:34   #8 (permalink)
Member: 856059
Thanks Meter: 124
sir i change it two times and also i change the display jeck sir give any other sol
Old 02-13-2009, 12:50   #9 (permalink)
fretburner's Avatar
Member: 45571
Thanks Meter: 45
All my N70 display problem that can call in and out are solved by either display ic or LCD.Sometimes needs to be reflashed after changing LCD.Try to double check your placement of the display ic sometimes not aligned properly.
Old 02-13-2009, 12:58   #10 (permalink)
Member: 856059
Thanks Meter: 124
i agree with you sir i also solve this pro in many n70 phones by changing display ic but in this phone i change two times display ic and also check all track and also change display jeck but pro not solved i am totaly confushed what is the fault in set i do everything in the end i think it is upp fault
Nokia N70 White Display Solution khisrow Nokia Hardware & Hardware Repair 15 06-26-2013 16:44
t 303 white display pro naeem iqbal Sony Ericsson Hardware Repair 0 02-15-2010 08:22
nokia n70 white display vaibhavdawar Nokia Hardware & Hardware Repair 3 09-08-2009 21:32
Nokia N70 White Display Hang NIMESHFONOTLY Nokia Hardware & Hardware Repair 7 10-07-2008 15:46
n70 when power on blink nokia then white display paraniselvanm Nokia Hardware & Hardware Repair 3 04-11-2008 09:19
Page generated in 0.18617 seconds with 9 queries
