Old 01-30-2011, 16:29   #1 (permalink)
Member: 1489864
Sonork: 100.1609401
Thanks Meter: 73
Arrow Reset Your Mobile Memory Card Password 2 minutes
We usually set password for our memory card for privacy and security, but the common mistake every one does at least once in out life time forgetting password. If you set password for mobile memory card, then you should be not forget the password. If you does then the only option is to formate your memory card with the help of the card reader and eventually the loss of all your data stored on it. There is a way to break the security wall. If you are a Symbian device lover then no need to worry about the password. You can crack them in few minutes.
In this tutorial I am going to teach you how to reset your memory card password in easy step. Before we start you need to have X-plore (application used to explore your system files and folder even the hidden folders in your device)
Step1: Install X-Plore in your mobile. If you want to download X-Plore search around internet you can download free trail.
Step2: Open your X-plore apps and Press 0(Zero) and check which you have marked the "show the system files"
Step3: Once you done that now go to the following path C:/Sys/Data/Mmcstore
Step4: Once you reached there you need to press "3" under option to set it in the Hex-viewer
Step5: See the third column you will able to see a line of code ! TMSD02G (c??"?x???6?2?6?2?6). Just check the character between the "?" it is your password ie: 62626
Note: If you have not set the password, then you will not able to gain access to C:/Sys/Data
The Following User Says Thank You to moin_mms For This Useful Post:
Old 02-02-2011, 19:38   #2 (permalink)
sathvik71052's Avatar
Member: 549926
Thanks Meter: 118
Br isit possible in s40 handsets.......there is no ex-plore in s40 phones ..how can i try...........
Old 02-02-2011, 19:40   #3 (permalink)
Member: 1507780
http://www.konceptalgo.com
Digital Image Processing,Image Slicing,Image segmentation,Image colorisation,Custom software development in india,conceptalgo,Image Processing | Image Slicing | Image segmentation
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
Page generated in 0.12070 seconds with 9 queries
