12-06-2002, 12:19 | #1 (permalink) |
No Life Poster Join Date: Jan 2000 Location: NL Age: 55
Member: 847 Status: Offline Thanks Meter: 36 | RSSI reading. Have trouble with RSSI reading using wintesla. Sometimes its ok, i get reading, but most off time i cannot. get error from wintesla. What is the problem? thanks Sjakie |
12-07-2002, 00:39 | #3 (permalink) |
Member: 847 Status: Offline Thanks Meter: 36 | Thanks for reply. On rssi reading it says:Failes to read dat from phone,reason no response. On menu RX calibration it says, failed to setRSSI high reference reason: no response. regards Sjakie edit.. sometimes it reads it ok other it says ''unknown pci error" Last edited by sjakie; 12-07-2002 at 00:58. |
12-08-2002, 06:21 | #4 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | sjakie Clean COBBA BGA PAD ang replace a COBBA! Willy Quote:
12-08-2002, 20:15 | #6 (permalink) |
Freak Poster Join Date: Jan 2001 Location: I.C., R.P.
Member: 3165 Status: Offline Thanks Meter: 0 | a little help, perhaps... greetings. i'm using the cracked version of wintesla. i have been following your postings regarding signal repair and the one you gave pertaining to RSSI readings using cracked wintesla really rocks. regarding my prob, i have a 3310 with no signal. replaced, hagar, vco, C508, and antenna switch. also tried replacing RX filters but still i get no RX/TX (using netmon). regardless of which part i replace, i still get RSSI readings between -117 to -118db. any help would be greatly appreciated. |
12-09-2002, 06:54 | #7 (permalink) | |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | Re: a little help, perhaps... Quote:
12-12-2002, 22:40 | #8 (permalink) |
Junior Member Join Date: Dec 2001
Member: 8041 Status: Offline Thanks Meter: 0 | @aZyWeRks u need rf generator to read rssi properly from fone..... if u hav no input signal to fone, then rssi reading will be out..... all rssi would reflect is input signal or close to that! to really know wut is happening with the rf in that 3310 pcb, u need rf generator to isolate rx & tx & check to c which is malfunctioning...... it is possible that pa is also faulty but again, u just shooting blind without proper equip...... @willy thanx for ur help rgds with wavtek...... i am still looking for 4107, need jigs also but ur price bit too much for me |
12-13-2002, 00:05 | #9 (permalink) |
Member: 847 Status: Offline Thanks Meter: 36 | Thanks for information. I tested lot off phones, 3310 8210 etc.. But if i have to change all the Cobbas from the phones that i cannot read, ...i think ill think dont live that long.... If someone could , when he has time, explain to me what i truly need to make a good diagnose off phone error, i would be gratefull. But i dont mean to buy the newest expensive equipment. I have money but to spend thousends off dollars i dont think i can earn it back. It suppose to make my life somewhat easier.... regards Sjakie |
6210 RSSI Readings... | Zoio | Nokia Hardware & Hardware Repair | 1 | 04-24-2003 18:50 |
RSSi reading -144dB solution? | hs_ | Nokia Hardware & Hardware Repair | 19 | 04-18-2003 23:05 |
Low RSSI reading ?!?!?!?! | unlockphone | Nokia Hardware & Hardware Repair | 3 | 04-14-2003 10:35 |
5110 RSSI reading | insidebga | Nokia Hardware & Hardware Repair | 1 | 01-04-2003 16:31 |
Please help with RSSI Reading | mujie | Nokia Hardware & Hardware Repair | 3 | 11-05-2002 17:00 |
