10-21-2004, 09:21 | #1 (permalink) |
Freak Poster Join Date: Apr 2003 Age: 47
Member: 25763 Status: Offline Thanks Meter: 18 | 6610 extract content failed I have a Nokia 6610 water damaged. I have cleaned the board througly using ultrasonic cleaner. But the phone refuses to switch on. I tried flashing with ufs/griffin but it shows error as below : Initializing Phone... Flash configuration: 9B020100EC22FA000000110200000001... Boot and Flash loaders operation took 5.177000 seconds Erasing - erase took 61.031003 seconds Flashing MCU - flashing took 62.432003 seconds Flash configuration: 9B020100EC22FA000000110200000001... Erasing - erase took 10.587001 seconds Flashing Content data - flashing took 4.761000 seconds Extracting content package . . . Wait phone ready..., Delay - Issue extract...Extract content FAILED Flash configuration: 9B020100EC22FA000000110200000001... Erasing - erase took 10.767001 seconds Flashing PPM - flashing took 12.116001 seconds Flashing DONE After flash processing... Trying autopower Fail can anybody please suggest ,why the content file fails to extract. BR |
10-21-2004, 17:27 | #4 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | @ supremegsm Try flash just the mcu and ppm first then try content package and ppm sometimes the handset will not go into local mode and that is needed to complete extracting content package Regards D. |
10-28-2004, 23:33 | #5 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | i have same problem, did u fix it by changing ram or uem? changing flash ic not solved my problem changing ram ic not solved my problem too. what else ? any idea? pali Last edited by pali; 10-28-2004 at 23:54. |
11-02-2004, 17:54 | #8 (permalink) | |
Freak Poster Join Date: Oct 2002 Age: 55
Member: 16430 Status: Offline Thanks Meter: 2 | Quote:
Yours also drown?Then check broken line from upp to rom & ram to rom. | |
11-02-2004, 18:02 | #9 (permalink) |
Junior Member Join Date: Nov 2004 Location: Orange Switch Age: 41
Member: 89713 Status: Offline Thanks Meter: 0 | Try this When you dropped your phone in the water, it will have caused corrosion under the IC's themselves. Try using isopropanal to clean the board, leave it to soak for five minuets. Any corrosion should disapear, even the corrosion under the IC's and the tracks within the main board itself |
Flash 6610i,Extract content fail | SangReal | MT-BOX | 6 | 06-03-2006 08:15 |
3120 extract content failed | linekbp | Nokia Hardware & Hardware Repair | 6 | 09-28-2005 13:50 |
Extract content FAILED | AndRe DCF-gsm | Griffin | 8 | 08-01-2004 19:03 |
7210 extract content failed!!!! | .:: SkyElectronic ::. | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 12-22-2003 08:36 |
Extracting content package . . . Extract content FAILED | Burnt Cobba | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 02-27-2003 18:35 |
