12-01-2009, 17:29 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: banglore\kerala
Member: 523496 Status: Offline Sonork: ammachis Thanks Meter: 76 | simple way to check whether the track is okay or not... HOW TO CHECK THE RINGER TRACK IS OKAY (I USE ANALOGUE MULTIMETER) 1.PLEASE TAKE THE MULTIMETER PUT IT IN TO OHMS LOW RANGE 2.PUT THE POSITIVE PROBE(RED)IN TO THE GROUND PART OF THE MOTHERBOARD. 3.THEN CHECK THE PART WITH THE OTHER PROBE(BLACK)EACH POINTS WILL SHOW A SLIGHT READING THIS IS KNOWN AS IMBIDENCE 4.IF IT SHOWN A SLIGHT READING IT MEANS THAT THERE IS NO TRACK BREAK BUT IT DOESNT MEAN THAT ITS OKAY CHANGE THE PARTS WITH UR SENSE.. THIS IS A VERY COMMON METHOD BY THIS YOU CAN CHECK WHETHER YOUR SIM IC KEY PAD IC RINGER IC ETC THANK YOU ALL THE BEST SUGGESTIONS REQUIRED AS IT IS MY FIRST ONE |
The Following 3 Users Say Thank You to Binoy.c For This Useful Post: |
Before using the simlock RPL, how to check if the superdongle is fine | moulnisky | Cyclonebox | 21 | 01-29-2010 04:39 |
how to check nokia bb5 rpl... its ok or not | Nokia-Shop | Universalbox | 3 | 01-14-2010 06:25 |
Fastest Way To Check If your SAMSUNG Support Arabic Or No At One Place | tsarkh | GSM Mobile Links | 0 | 12-24-2009 17:04 |
check your nokia mobile is orginal or not | shahidsattar | Nokia Hardware & Hardware Repair | 19 | 06-01-2009 06:47 |
How to check if the 3310 is shorted? (how to use multimeter for checking the line) | sapatos | Nokia Hardware & Hardware Repair | 3 | 09-04-2005 10:33 |
