..:: Solution Of Imei ?????????????? Is Here ::.. all you only need is UFS and GRIFFIN 1. download all imei patches of JAF 2. flash the phone with mcu and ppm with its correct version (ex.. 8310 v6.20) 3. now put NHM-7V06.20.fia in ppm 4. flash it without MCU.. 5. check info... you will notice that imei will be --- *** if you insert a sim card it wont accept any. phone restricted will appear 6. ufs can't unlock this phone so its time for the griffin box to do the unlocking... after that check it out!!! you now have a phone with an invisible imei!!! hehehe!! if you check *#06# you cant see the imei... heheheheeh ***Tested working with my 6100 and 8310, so u all know what to do.. DOWNLOAD IMEI PATCHS FROM HERE |
Hi, Good solution. So i assume you were in rush and tested it only on working phones ? Regards |
if UEM IMEI is corrupt then how do you expect the phone to log onto any network?? |
anyone tested his solution or not???? |
Yes.. I agree with u. For corrupted [data 2] no way with this. What about the watchdog??:confused: regards |
Agree with you too OM GEMBUL !!! |
hmm. look like a good information here, i will test that ! BR., Denis |
solution works 100% for 30 seconds before watchdog shuts the phone down. |
Then what kind IMEI sees the network provider?! |
This solution is 100% fake.....after that operation the phone can't make a call(if Flash IMEI is broken)!!!! |
I've tested and it doesn't work for corupted UEM Imei with watchdog problem. Even ASK to RPL from Griffin server also didn't help. |
Pls Close This Thread Pls Close This Thread For The Sake Of Others This Fake The Only Solution Is Change Uem. TESTED IN 8 PCS PHONE AFTER PUT PATCH PHONE SHOTDOWN. |
I don't think DCT4 direct also couldn't solve UEM IMEI corupted. |
tis solution cant work at all. after patch got network but auto shutdown after 30 second. it cant match data2.. |
