***** Solution Imei ?????????????? WORK 100% ***** 3 Attachment(s) 1 download all imei patches of JAF 2 flash the phone with mcu and ppm with its correct version 3 now put files.fia in ppm flash without MCU 4 check info imei will be --- 5 look picture step 3&4 6 edit imei number Tested working with 3100 link PATCH UFS http://rapidshare.de/files/15965753/...RSANA.rar.html |
Hello bro any other solution for nokia 1100 & 2300 without change UEM? |
Hi Are You Sure For This Men |
this is not the complete solution because after paching ur phone will restart 30 sec ,only changing new uem is complete solution thnks |
Sure 100%%%%%%%%%%%%%% 3 Attachment(s) Hi Are You Sure For This Men |
No Patching For 1100,2300????????????? |
hi, this means you can use power flasher in patching dct4? ???? IMEI will restart after 30 sec. when patched... |
Link Is Not Work ........bro |
link is not working......................... |
BAYOO |
yes changing new uem is complete solution ok |
try to use search function on tis forum befor post .... its an old solution ,, but not working well ... cos the 32 sec watch dog still turninging the phone off after the patch ...its not a solution |
i tested man .. before weeks and works with all dct4 will .. just if you lose imei net UEM problem .. 1- flash phone with any flash 2- edit imei 3- flash phone with latest flash 4 edit again imei 5- full reset and unlock 6- thats allllllllllllllllllllll 100% |
thnksssssssssssssssssssssssssssssssssssssss BoOzer665 |
yes if uem be ok no problem but often rebuild uem which we doing |
