Old 05-19-2008, 08:41   #1 (permalink)
DIGITAL BABU's Avatar
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
some dct4 hang then restart problem what solution
hi all,
i found some time some model 6100, 3100, 1110, 1600, 6610, and etc.
hang 5 second then restart
i try flash and flash change verson via jaf, ufs3 but problem is stile.
what's problem hardware or software?
thanks all
The Following User Says Thank You to DIGITAL BABU For This Useful Post:
Old 05-19-2008, 08:54   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
try to chaing battery ........
The Following User Says Thank You to nasirkhan007 For This Useful Post:
Old 05-19-2008, 09:00   #3 (permalink)
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
try it but not done
thanks
Old 05-19-2008, 11:14   #4 (permalink)
Member: 306004
try to rehot the cpu or write the good pm and flash it to a new version . try it
The Following User Says Thank You to dragon0298 For This Useful Post:
Old 05-19-2008, 11:35   #5 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
Originally Posted by DIGITAL BABU View Post
try it but not done
thanks
" i read ur most of the posts by which i can easily assume that u hav done software in every fashion erase, changing version etc since u havnt mentioned abt hardware by working on upp will be the handy, thanx"
The Following User Says Thank You to mobilespeed For This Useful Post:
Old 05-19-2008, 12:49   #6 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
hi all,
thanks all
brother i think this problem mainlly hardware
like 13Mhz or 26Mhz CRYSTAL
CHNAGE THIS PART THEN AM SOLVED THIS SAME PROBLEM 1112,1600,1110,2310 ETC...............
ABOVE 100 HANDSET SOLVED SAME PROBLEM
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 05-19-2008, 13:05   #7 (permalink)
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
hi,
thanks for repley bro.
possible to help me with any image for 6100
again thanks u
Old 05-20-2008, 14:13   #8 (permalink)
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
@ SHIJILFONOTLY
i am waiting for you.
pls come back you with my wanted image
thank you!!!
Old 05-23-2008, 08:09   #9 (permalink)
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
i try to change but problem is not done.
pls anybody another idea for 6100 hang 5 second then restart
Old 05-23-2008, 08:16   #10 (permalink)
willydewi's Avatar
Member: 331835
Thanks Meter: 64
Change UEM ic....good luck
The Following User Says Thank You to willydewi For This Useful Post:
Old 06-14-2008, 15:24   #11 (permalink)
Member: 757672
Sonork: 1575834
Thanks Meter: 34
no in uem or scl
this proplem in flash or ram
or flash if compo ram in flash
coz the phone work normal when u press on keypad the phone restart
The Following User Says Thank You to Do7a GSM For This Useful Post:
Old 06-14-2008, 18:06   #12 (permalink)
Member: 222373
Thanks Meter: 9
Bro,
Just Reball Flash IC with good flux & BGA reballing past like PPD.
this is the common problem of S40 DCT-4 phones like 6610, 3100,3120.
if in any case reballing flash ic solve your problem then you will also have to reball CPU. this is just because of dry solder under Flash IC & or CPU.
BR,
Vilas Vanjari.
The Following User Says Thank You to vilas_vanjari For This Useful Post:
Old 06-15-2008, 08:43   #13 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
try to rehot the cpu or write the good pm and flash it to a new version .............
The Following User Says Thank You to sujan1050 For This Useful Post:
Solution For Z370 Hanging And Restarting Problem! aikonmani UST Pro II 5 07-07-2011 11:46
k 770i hang then restart . nangia khan Sony Ericsson Hardware Repair 1 03-29-2010 04:56
x200 hang & restart problem maheshsaiganesh UST Pro II 2 11-01-2009 13:55
Lobster 485 hangs then restarts zeerik Infinity-Box 1 10-21-2009 23:00
3310 hang and restart problem NITINWADHWA_NIT Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 10-08-2005 16:11
Page generated in 0.21712 seconds with 9 queries
