10-10-2002, 18:24 | #1 (permalink) |
Insane Poster Join Date: Mar 2002
Member: 10015 Status: Offline Thanks Meter: 0 | some tips for 3310 no network I have some tips for repairing no network 3310. I had 3 pieces of 3310 with this sympthoms: No network, but in search mode - select network you can find any networks. next one is : after start phone log to network, but after few seconds no network. I was fix that by replace BGA amplifier with new one and all working good. I was all poland models of 3310. May be my sugesstion can help someone |
10-10-2002, 18:34 | #2 (permalink) |
Member: 10015 Status: Offline Thanks Meter: 0 | I forgot, befor you replacing BGY, you should check soft. by some nok. tools, try to recalc. secur. checksums or flash with full (with eep.) and calcul. secur. checksums and locks to eliminate soft. problems. If your phone log to network and lost network and restart, it is probably soft. problem (wrong checksums) good luck |
10-11-2002, 23:55 | #7 (permalink) |
Member: 10015 Status: Offline Thanks Meter: 0 | I have one, change diplexer (was bad) BGY, dualsaw filters , reheat cobba, ccont,hagar,change 26MHz VCO and nothing changed. Phone can switch on, but can't get on network (soft is ok). I think it can be in power way to rf parts, but I don't know where I need to meansure voltage (on witch component??). Thank You!!!! |
10-13-2002, 21:07 | #10 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Flashman, rehot or reheat will not help so much ! best way to do , step by step to measure all point you need ! SW :wintesla ( DCT3),phoenix (DCT4) tester: oscilloscope ! you have to test all power supply from ccont ! then use SW to enable RF control, and go to test "IP/QP" from hager to COBBA ! Willy Quote:
10-13-2002, 21:40 | #11 (permalink) |
No Life Poster Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | hi willy i learned alot by yor prevous posts(thanx man)however one thing is not clear for me ,when u take apart the phones how do u give it a current? i know there r test points but where r they and how do u connect the bare board to the power supply? br farry |
10-13-2002, 21:45 | #12 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | Farry, 1: use test jig ! 2: if you do not have test jig, then you solder a 10K ohm resistor from BSI pin to GND , and give 4V to Vbatt ! then you power up your phone without battery ! Willy |
10-13-2002, 21:46 | #13 (permalink) |
No Life Poster Join Date: Mar 2002 Location: khonkean,thailand
Member: 10084 Status: Offline Thanks Meter: 283 | hello willy i have problem with 3310 no net. phone A : RSSI 110 db .manual search no network.Tx set to level 10 phone turn off phone B :RSSI 108 db .manual search ok.Tx set to any level not happen but PA not damage how to solve best regarde |
10-13-2002, 21:53 | #14 (permalink) | |
Registered User Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | Re: hi Quote:
10-13-2002, 22:04 | #15 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | Srtrech, Phone B, use oscilloscope to check Hager to VCO loop ! and see VTX from CCONT, and TXC from COBBA working or not ! then Check PA output level and TXVDET to Hager then Antenna switch ! phone A, check Vbb for Hager and remember have "load " for TX , and test it again ! and reball COBBA ! then see that RX IP/QP ! Willy ps. sorry Srtrech , i make mistake for that URL . I send to you by mail ! Last edited by willy; 10-13-2002 at 23:32. |
3310 no network,no signal | xyzjojo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 14 | 11-14-2013 04:27 |
Please give somes tips for keep alive our ub | NEO-TECH | Universalbox | 1 | 11-23-2009 00:10 |
3310 DAED AND 3310 NO NETWORK | ezz2003 | Nokia Hardware & Hardware Repair | 9 | 06-16-2007 18:03 |
some tips for nokia | REMO | Various | 0 | 04-23-2005 08:02 |
3310 NO Network | miga | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-10-2001 13:57 |
