12-03-2002, 21:22 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Location: North Pole
Member: 12869 Status: Offline Thanks Meter: 3 | Mr Willy, 8210 no signal I read in an old post, you wrote and I quote "use wintesla to run test menu -> rf test and set RX, with ch 60 then test VCO C558, see is it 2.745v 1. my problem is I've got 2 nokia 8210 with no signal, with rssi reading -118, what do i change 2. Sorry to sound stupid but how do I measure VCO C558 using wintesla thanks alot, Black-Axe |
12-03-2002, 21:42 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: Mr Willy, 8210 no signal Black-Axe, sound not "stupid", at list you try to know what happen your phone, and it correct way to repair phone TO measure C558, it is for 3310, to know loop from Hager to VCO ,,it can be range from 1.2V to 3.2V at around 216 hz,, you have to use oscilloscope to "see" it ! first check VRX , VTX, V,,,,,, from CCONT , and for 8210, you have to measure that VCO at C802 !( by oscilloscope) and go to R530 ( in RX brust mode) to see that RX IP/QP -> oscilloscope too ! for your 8210, that RSSI -118dbm, how about TX ? is TX working ? TXP, TXC and TX detect, you have to measure it too ! most time, if it is -118bdm, i will check antenna switch , and 26Mhz Vp-p, and COBBA ! Willy Quote:
12-04-2002, 02:11 | #3 (permalink) |
Member: 12869 Status: Offline Thanks Meter: 3 | Thanks alot for your quick reply Willy, I will have to get oscilloscope soon, which is the best to get, I mean the cheatest, that can do that job properly. THANKS |
8210 no signal | classic mobiles | Nokia Hardware & Hardware Repair | 2 | 01-04-2006 10:52 |
8210 no signal pls help | etcelfon | Nokia Hardware & Hardware Repair | 8 | 10-06-2004 09:31 |
2 nokia 8250 - 8210 no signal . same problem ? | arif_tual | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 02-05-2004 13:09 |
To Mr. Willy. 8210 doesn`t get service | BadSector | Nokia Hardware & Hardware Repair | 1 | 12-27-2002 10:46 |
8210 no signal | BorisBonk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-26-2001 11:52 |
