02-24-2009, 12:43 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DERAMOBILE DGKhan pakistan
Member: 388454 Status: Offline Thanks Meter: 1,101 | structure nokia bb5 Handphone nokia newest that has dual processor group bb5. This group handphone has technology is not has by group nokia previous (dct3, Dct4, Dct4wd2). Handphone nokia bb5 like nokia 6630,6680,6680,6681, N series. I. Processor Second processor that play important role as brain from handphone: Rap3g (3g radio application processor) that functioned to regulate handphone principal work process. Tension that got from retu that is vio 1,8 volt, with vcore 1,4 volt from tahvo. Omap (open audio multimedia processor) that functioned to regulate interfaces user likes camera, Mmc, Keypad, Lcd, Etc. Omap get supply tension from retu that is vio 1,8 volt. Each processor has memory self. Rap3g has nor flash+sdram, While omap with ape combo memory Ii. Memory As data repository that wanted by handphone is used kind memory as follows: Nand flash (ape combo memory) that accessinged by omap processor. Memory this contain application datas with user interfaces user arrangement data. Nand flash get supply tension from ic power retu that is vio 1,8 volt and Vdram 1,8 volt. Nor flash+sdram (cmt memory) that is memory that contain principal function vital datas from handphone contain firmware, Calibrate and Certificates id. Supply tension vio 1,8 volt from retu. Iii. Regulator power supply Component power supply or More knowledgeable with the title ic power in handphone bb5 this also divided be two parts that is: Retu ic power principal that have a duty to give supply tension in cpu, Sim card, With startup power and Another vital tension. Also processed signal audio (vibrator, Microphone, Arphone and Speaker phone). Damage in retu dpt causes handphone dies total and Another damage. Function other from retu that is regulate illumination led good lcd/keypad led. Keypad led will not burn moment will reside in bright room. Als (ambient light censor) this lay in casing in front of handphone shaped photosensitive transistor. Tahvo ic power second that have a duty also give tension to cpu, Admission filling tension battere (charger), Tension flashing, With tension led. Doesn't like dct4, In ic powernya uem that contain number security data imei, So in retu and Tahvo there is no security data inside, So that replacement retu and Tahvo this is not need admission filling security area as does dct4. Iv. Rf (radio frequency) ic Component signal processor in handphone bb5 also divided two components that is: Hinku receivers component signal (receiver). Signal that step into handphone is cultivated by hinku then be sent to aim rap3g and Outputnya in speaker. Vinku transmitter component signal from mic aim rap3g to vinku and Braced by pa and Radiated to aim provider. . V. Another component Pa gsm wcdma have a duty to brace ouput signal that from vinku. Antenna switch regulate receivers stripe and Transmitter signal enter and Out. Bluetooth ic controls work function bluetooth for data transfer in frequency wave 2,4 ghz. With know and Detect component with the work function, So we can easily detect and Detect damage origin in the event of problem in handphone nokia this newest group. |
The Following User Says Thank You to shahidsattar For This Useful Post: |
How to know Nokia BB5 Engine Structure | faisal4friend | Nokia Base Band 5 ( BB-5 ) | 1 | 07-27-2009 09:32 |
2 Nokia BB5 Tested 2 Nokia BB5 ****ED !! | makroud | Cyclonebox | 34 | 07-04-2009 01:54 |
How to know Nokia BB5 Engine Structure | saifali | J.A.F. By Jafsupport.com | 0 | 03-25-2009 19:25 |
Poll : The best BB5 Nokia flaher 4 nokia bb5 ? | Professional | Nokia Base Band 5 ( BB-5 ) | 1 | 09-09-2008 01:07 |
imei structure of BB5 | XenKo78 | Nokia Base Band 5 ( BB-5 ) | 5 | 05-18-2006 19:24 |
