01-30-2007, 13:21 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: EGYPT-ZAGAZIG
Member: 234790 Status: Offline Thanks Meter: 4 | technical question is the direct heater on 3220 pa corrupt it? i mean when i replace 3220 pa should i heat under the pa or its ok to direct hot air directliy on it? thnx hany the egyptian |
01-30-2007, 16:57 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | friend direct heat on PA should damage PA you should apply two steps to fix PA on any set first > while open faulty PA keep hot air gun on that place , apply good flux on that area then place new PA apply more flux & give a little heat surrounding of PA second > in some sets you can heat back side of pcb for changing new PA & apply good flux around PA hope this will help you |
ASK TO RPL technical question | 2xxu | Nokia Base Band 5 ( BB-5 ) | 11 | 05-08-2009 16:26 |
Technical question regarding Centro and USB Modem | wutzthedeal | PalmOS /HP and others | 1 | 12-19-2008 04:46 |
Technical Question about unlocking with server | tes_vortex | Sony Ericsson | 1 | 06-14-2005 06:19 |
a technical question about CELL TRACK | mohsen643 | Nokia Multimedia | 0 | 06-08-2005 21:02 |
Technical question... | michel-2000 | Phone Unlocking Codes & Maps | 0 | 11-12-2003 05:13 |
