Old 01-18-2010, 09:50   #1 (permalink)
Member: 1427033
Sonork: 100.1596688
Thanks Meter: 1,204
Arrow These are the most common faults found mobil phons :
THESE ARE THE MOST COMMON FAULTS FOUND MOBIL PHONS :
1. Mobile Phone Dead
2. Insert Sim Card Problem
3. Hanging Problem
4. Network Problem
5. Mic Problem
6. Ringer Problem
7. Speaker Problem
8. Vibrator Problem
9. Display Problem
10. Mobile Restart/ Switch Off Automatically Problem
11. Call Cut Off Problem
12. Charging Problem
13. Keypad Problem
14. Sim Lock/ Mobile Lock Mobile
15. Contact Service/ Contact Retailer/ Contact Manufacturer
16. Battery Discharge Problem
17. Gallery Not Opening Problem
18. Camera Problem
19. FM Radio
20. LED Problem
21. Memory Card Problem
22. Bluetooth Problem
check either handset is Short, open or
leakage
check continuity by meter at positive and negative terminal of battery connector
if meter shows deflection on both side means its SHORT...
If its one side full and other side slight deflect means LEAKAGE...
if it does not deflect any side means OPEN....
AND if deflection is one side only then its OK. This method is applicable for all mobiles
_________
How to Repair a Dead Mobile Phone
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting does'nt go it may be due to shorting in an ic,capaicitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic bacomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
[/COLOR][/SIZE]
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU
The Following User Says Thank You to Dooha_Bd For This Useful Post:
These are the most common faults found mobil phons : Dooha_Bd Nokia Hardware & Hardware Repair 0 01-18-2010 09:42
these are the fones that furious are meant to do! flashfone FuriouS II 5 08-30-2005 13:58
Most common faults? The_Designer Hardware Equipments for GSM 0 07-26-2005 10:43
Teleway and ONE-STOP-FACTORY are the most honest person I've ever seen! Qbe The Market Feed Back 7 02-18-2004 11:30
Page generated in 0.14632 seconds with 9 queries
