Is It true? if eras flas the phone cant flash i use ufs it warned me if im erase the flash it cant flash it again? |
For example: > You are going to erase 1600. > You mistakely selected 1208 in UFS Suite. > You pressed Erase Button. > Flash IC of 1600 will be erased as the IC of 1208 and may cause to delete Permanent Memory Area or may cause corruption because every set has different flash areas. > After erasing you may realize your mistake but it can not be undone. > That is why UFS warns you before erasing any phone. At last, I want to clear that you may Full Erase and Flash your phone to turn it on but may need to write PM file. Br, Shadab Ahmad |
thanks brother.. why we should write pm? |
It is not true when you were erased the full flash it cant flash it again. Thankz. Xtreme Mobile. BRB. |
thanks for your information |
thanks .. now my phones work |
we can still flash the phone after erasing..but we must write also pm....file..why? so that our phone will still have a signal..because if we erase the flash after writing there will be no signal if we dont write pm.. |
No dear it is not possible. But out of 100 phone 1 phone show this type of problem. |
Ian with sigma xi.What we will do in 1200,1208,2760,1650,& many more new model amol_sm????????? Thankz. Xtreme Mobile. BRB. |
And the same applies for DCT3. Am I right Bro? |
re: Quote:
