uBGA problem... 2 Attachment(s) 1) this is the uBGA net (stencil) with open container of soldier paste, 2- soldier paste: written on lid : advanced quality, joint high density high immersion, Its like in a solid form when cold, but when i heat it with gun or put soldier iron into it it becomes a thick liquid.(paste) u can heat this in the tin forever it does not seem to becomming soldier, when leave to cold it becomes hard again. |
Keep the stencil Throw the other paste in the garbage and then go to www.warton-metals.co.uk and buy some high quality solder paste/flux etc |
sorry sir, but that container is not solder paste... it is solder FLUX... this you apply on board/ic before making the soldering. it helps the solder to flow once melted... |
They are useless anyway. He probably will make more damage if he uses it. |
aha... knew i was doing something wrong, thanks for the update peoples. time to go shopping ! :D |
you have others selections .... use TIN BALL ! |
But he needs to buy a special stencil kit for solder ball use :) |
is the stencil i showed in the attachement for use with soldier paste only?? Do i have to get another stencil now to use the balls, cos the balls i managed to get are written 0.4 and 0.5 do these have different stencils & how do i make sure which stencil is for paste and which for balls.... tia |
I prefer solder paste. works better for me, if you practice you will get it fast enough |
Sorry but china solder paste that come whit reballing kit is very very bad, try to go in a good electronic shop and buy good paste.;) |
I am ordering very good soldier paste today, when it arrives I will attempt to re-ball then post results, thanks for all replies. Br |
Could you please give a name of good solder paste? I also purchase reballing kit made in china and never made it... then finally i'm using thin ball. |
Solder Paste Solder Paste (Grey) R 28.07 R 32.00 this is what stands on my order sheet, ask for soldier paste grey, with a mud texture, secondly, are u applying paste balls to stencil then heating while in stencil or removing the stencil then heating...?? Br |
I've tried both, heating first and heating after removing and the result is not good. I've read in the forum that the correct method is heating the paste while in stencil. |
re 5 Attachment(s) OK, here is what i bought today... all thanks goes out to MUJIE :D |
