09-21-2009, 04:46 | #1 (permalink) |
Insane Poster Join Date: Dec 2004 Location: REHAB CITY/ CAIRO Age: 66
Member: 102012 Status: Offline Thanks Meter: 31 | universal solutions for N70 white screen &hang up by:A- TAHSEEN 1st, we should know what is mean white screen 2nd, what is the real solution 3rd, how can we apply the solution 1st - WHITE SCREEN means 2 cases: A) mobile works completetly , but with no lcd data: REASONS are: LCD- LCD CONNECTOR -LCD FILTERS- CONNECTIONS -LCD VOLTAGES(VIO-VAUX)- OMAP. B) mobile only white screen with no validity( no tx,rx- no voice at earphone): REASONS are: SOFT WARE -POWER SENSOR- FLASH IC - OMAP 2nd - when we have the 2nd case we can start with soft ware then check if OMAP has the requierd power for work or not, (Vcorea- 1.4 volt)- then we rehot flash ic even if it is isolated (with carefull)- at last may be the reason is OMAP itself 3rd: how can we apply the solution? here i mean especially if the problem is POWER SENSOR (SMPS), N4200- we have first to rehot , then take out the POWER SENSOR from the board and make the suitable solution from what i`m giving you below : i made the (vio ) capacitors with the blue colour - and the (vcorea) capacitors with the green colours and you have to make the bridge between any one of (vio)s and any one of (vcorea)s- that is of course to give a suitable volt for OMAP power and we have also to chose the nearest capacitors of both on the board , and below you can see i made 3 circles around the nearest capacitors i hope you`ll like it and it will be usefull for all : Best Wishes For All Till We Meet Again, Ahmed Tahseen |
The Following 14 Users Say Thank You to tahseen For This Useful Post: |
I Need Tested Solution 4 N70 White Screen | ..::khaled::.. | Nokia Hardware & Hardware Repair | 15 | 07-23-2008 08:15 |
solution for N70 white screen | kwasasco | Universal GSM Software | 2 | 06-27-2008 14:04 |
all jumper for n70 white screen | hamed_0915 | Nokia Hardware & Hardware Repair | 10 | 06-16-2008 07:38 |
help for N70 white screen after change sim ic | chronic | Nokia Hardware & Hardware Repair | 1 | 01-22-2008 20:40 |
Many Shorting Methods For N70 White Screen-which One Is Working -help Me? | zone2 | Nokia Hardware & Hardware Repair | 3 | 11-06-2007 08:27 |
