09-18-2007, 05:44 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 584065 Status: Offline Thanks Meter: 10 | Urgent Nokia N70 Memory card Coruppted Problem |
The Following 6 Users Say Thank You to aaronixsoni For This Useful Post: |
09-18-2007, 06:22 | #2 (permalink) |
Freak Poster Join Date: Jun 2005 Location: http://www.paybox.me/r/mourad1 Age: 47
Member: 155016 Status: Offline Thanks Meter: 130 | check whether MMC_Card_Reader is good by using another Card ...if yes then the First Card u mentionned is faulty ... Otherwise , u need to check MMC_Interface on PCB (Reader , Emi_Filter , Shifter ..) . Best.Regards |
The Following User Says Thank You to Mourad120 For This Useful Post: |
09-18-2007, 07:12 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: cavite phils.
Member: 455665 Status: Offline Thanks Meter: 36 | no solution regarding MMC corrupted, but you can try to format it w/ card reader into computer, then format it again into your phone, if not fix! find trash can and make your 3points shot, gudluck! |
The Following User Says Thank You to tabuki For This Useful Post: |
09-19-2007, 16:49 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks Meter: 97 | H ave you tried to use another MMC so you can identfy the problem.I f its MMC or the phone. |
The Following User Says Thank You to manyosa For This Useful Post: |
09-19-2007, 20:26 | #5 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | Hi, Put Back The Mmc On Your Mobil Set. Then Go To The Manu Then Tools Then Go Extra Then Go Mmc Card Then Option Then Mmc Format....thats All.... Thank You... |
The Following User Says Thank You to sopnil For This Useful Post: |
09-20-2007, 15:09 | #6 (permalink) |
Freak Poster Join Date: Mar 2006 Location: india
Member: 247228 Status: Offline Thanks Meter: 130 | Urgent Nokia N70 Memory card Coruppted Problem hi dear use mmc corupted repair in one apps ( mmc medic) this apps corupted mmc repair put card in card reader then repair good luck...... |
The Following User Says Thank You to simtech For This Useful Post: |
02-19-2009, 08:39 | #9 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Near In Your House Age: 40
Member: 974072 Status: Offline Thanks Meter: 43 | Hi there try 2 used another MMc 2 identify if the phone or the MMc have prob........... Or try 2 format the MMC 2 ur phone............ |
The Following User Says Thank You to .::CPU_3660::. For This Useful Post: |
11-25-2009, 09:32 | #10 (permalink) |
Registered User Join Date: Jul 2008 Location: (India) Age: 41
Member: 804452 Status: Offline Thanks Meter: 249 | Nokia N70 try mmc jumper & voltage proper , mmc detect but show memory card corrupted format option clik ,show hang only main problam memory card not format pls any solution very urgent me Hariom |
Nokia 6300 Memory Card Problem | .:SUBRATA:. | Nokia Hardware & Hardware Repair | 24 | 12-10-2011 13:27 |
nokia 6233 memory card problem | .::Moby World::. | Nokia Hardware & Hardware Repair | 1 | 03-11-2009 14:59 |
need solution for nokia 6280 memory card problem | EMSS | Nokia Hardware & Hardware Repair | 2 | 07-12-2008 07:53 |
nokia 3230 memory card problem | abrarmultani | Nokia Hardware & Hardware Repair | 1 | 04-18-2008 14:30 |
