10-04-2007, 05:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | use second hand uem on working pcbs solution here How to use un fixed uem from Asic 5 and asic 6 phones on asic 2 phones? step by step here: 1- Change Uem Ic 2- Then check ur phone working or not working (If not working then connect to your with flasher and make full erase.) 3- Then Full Flash Phone. 4- Write Pm File 5- connect phone to your flasher and get the imei number in uem 6- Open Ufs and Click Read Uem Write the imei u get in action 5 then click ok. 7- and now ufs ask u uem changed? enter "0" then click ok 8- now convert your ask to rpl and write your rpl file 9- unlock option done!!!!!! How to use unfixed uem from Asic 2 and asic 6 phones on Wd2 and asic 5 phones? step by step here: 1- Change Uem Ic 2- Then check ur phone working or not working(If not work then connect your with flasher and make full erase.) 3- when erase option finished click erase Flash and make all these adresses erased manualy start: 00000000 end: 00FFFFFF start: 02000000 end: 02FFFFFF start: 04000000 end: 047FFFFF start: 00010000 end: 0000FFFF start: 02000000 end: 00FFFFFF start: 02FC0000 end: 0286FFFF start: 02A00000 end: 0000FFFF 4- Then Full Flash Phone 5- Write Pm File 6- connect phone to your flasher and get the imei number in uem 7- Open Ufs and Click Read Uem Write the Ýmei u get in action 5 then click ok 8- and now ufs ask u uem changed? enter "0" then click ok 9- now convert your ask to rpl and write your rpl file 10-unlock and format user area done!!! How to use unfixed uem from Asic 2 and asic 2 phones on asic 6 phones? step by step here: 1- Change Uem Ic 2- Then check ur phone working or not working(If not working then connect your with flasher and make full erase.) 3- Then Full Flash Phone 4- Write Pm File 5- connect phone to your flasher and get the imei number in uem 6- Open Ufs and Click Read Uem Write the Ýmei u get in action 5 then click ok. 7- and now ufs ask u uem changed? enter "0" then click ok 8- now convert your ask to rpl and write your rpl file 9- unlock option done!!!!!! All member are apply and post the results Muhammad Afzal Meo |
How to repair using 2nd hand uem | shahidsattar | Nokia Hardware & Hardware Repair | 7 | 03-11-2009 06:57 |
how to repair using 2nd hand uem | shahidsattar | Nokia Hardware & Hardware Repair | 0 | 03-09-2009 06:52 |
1200/1208 power on in fbus cable but can't power on in battery solution here | joauz | Nokia Hardware & Hardware Repair | 6 | 12-17-2008 06:29 |
---trend t500 dual sim second sim is not working any solution--- | makkah mobile | Infinity-Box | 1 | 09-12-2008 09:26 |
<<<Booommm use second hand uem on working pcbs solution here>>> | υИқИΘШИ® | Nokia Digital Core Technology 4 ( DCT-4 ) | 17 | 09-23-2007 12:55 |
