08-02-2006, 07:53 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | vco in general ... need professional advice to test VCO in general in nokia phones, since ordinary or basic test insrumnets does not test such a high frequency device more than 3 ghz , and also the hp 8922m ( up to 2 ghz ) test set also does not have the ability to test this device , is there is ny trick or method to test it ...? does the control voltage enogh to verify the vco is working or not ...? |
08-15-2006, 08:13 | #4 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Philippines Age: 52
Member: 167822 Status: Offline Thanks Meter: 13 | Check its voltage using plain multimeter, if steady 5 volts VCO not working,if no 5 volts No VCP (charge pump voltage) VCO varies voltage depending on the channel monitoring notice that our Vbatt is only 3.6V UEM/CCONT produces step up 5V for voltage controlled oscillator for tuning in the bands desired. Put unit in test mode if you want full swing frequency output |
08-15-2006, 09:31 | #5 (permalink) | |
Member: 39208 Status: Offline Thanks Meter: 152 | Quote:
Need support withMT6235 in general, Cesim A9530 in detail | bollland | Chinese Models & Cloned Phones | 19 | 01-18-2010 13:42 |
Supporter in special/forum member in general | Fantoz | MT-BOX | 5 | 01-20-2007 21:46 |
CSR devices in general and firmware.... | lucke | Bluetooth-Software | 4 | 08-04-2004 20:21 |
** cheaters in general** | er2000 | The Market Feed Back | 3 | 06-09-2002 17:11 |
unlocking in general | jamez51 | Off Topic Zone | 1 | 10-26-2001 19:46 |
