08-28-2009, 06:57 | #4 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Bhumi Sang Mpu Aryya Wiraraja.
Member: 616567 Status: Offline Thanks Meter: 187 | How to repair corrupt IMEI with www.FuFeNu.in If the unit has a corrupt IMEI (????????????????4), it's most likely that unit have a BAD FLASH IMEI. There are many reason for having a corrupt/bad FLASH IMEI. 1. wrong flashing and PM secured area was accidentally written. 2. writing a different or wrong RPL. 3. etc. etc. To repair this kind of problem. you must get the RIGHT calculated FLASH IMEI (RPL) for the said unit. To do this. First you must make sure you have the RIGHT IMEI that is the same inside UEM IMEI. Here , you must use your devices to READ ASK. but each device has it's own way of reading ask. Here are some tips, for best way is to get the UEM IMEI... that will make sure you will have the same FLASH and UEM IMEI. 1. on UFS. i dont think it can read the UEM IMEI for now. but JAF, UB and MT can. 2. also, checking the back sticker will help also. but with lot of recon unit here in the ph. 3. it's really READ UEM IMEI that will stop you guys from having a bad RPL request. |
The Following User Says Thank You to sharlen For This Useful Post: |
Video how to change imei i900 with ust2 | raulka2003 | UST Pro II | 0 | 10-27-2009 14:05 |
Video How to change IMEI 1650 | smsismail | Cyclonebox | 3 | 08-29-2009 05:12 |
Video How to change IMEI Nokia | WHED | Nokia Hardware & Hardware Repair | 1 | 08-27-2009 16:59 |
Video How to change IMEI Nokia | ali_jaan | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 05-23-2009 18:45 |
