06-14-2002, 03:17 | #3 (permalink) |
Freak Poster Join Date: May 2002 Location: FRANCE Age: 46
Member: 11779 Status: Offline Thanks Meter: 0 | I cannot tell you how to fix it,but i can tell you how you can try to! If it's a lot of oxidation on it put the mainboard in a recipient full of alcohol 90%,Leave it there for a day and after that try to power on again! Sometimes it works! Regards |
06-14-2002, 09:38 | #4 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | Try using an ultrasonic cleaner, that get rids of corrosion. Also Trichloroethene is an excellent cleaner commonly known as car brake cleaner. |
06-15-2002, 14:49 | #5 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Ireland Age: 54
Member: 10516 Status: Offline Thanks Meter: 1 | I clean pcb with ulrasonic cleaner, use Isopropyl Alcohol. But after that pcb all contacts I find with withe oxidation?! Give me please dirrection where I can get Trichloroethene Cleaner. Best Regards Andrews |
06-16-2002, 17:30 | #6 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | Hi, I have an 8250 fell in water, then I immerse it in Ultrasonic solution for 1 hour then let it dry thoroughly.. then next day i power it on, it's working but easily drain battery and the unit is hot, so I suspect Power AMp IC has defect, so I replace it but still not functioning properly and no signal... i tried to Flash new MCU+PPM but gave me "FLASH ID UNKNOWN : 2656F209 ERROR: WHAT IS WRONG??? Thnaks to those who can help.... BR, Epic |
06-16-2002, 21:13 | #7 (permalink) | |
Crazy Poster Join Date: Oct 2001 Location: Croatia, Zagreb
Member: 6960 Status: Offline Thanks Meter: 0 | Quote:
If that don't help try the same with flash chip. If that don't help then maybe you will must to desolder cobba, make new balls and solder it again. But then there is always chance to kill cobba. Regards, Nicos | |
06-17-2002, 08:23 | #8 (permalink) |
Member: 11937 Status: Offline Thanks Meter: 1 | Trichloroethane is found in car brake cleaner. Go to your local petrol station and buy a spray can, just be careful, its poisonous. It clears out corrosion pretty well. If its getting hot, you probably have a short somewhere, that would also explain the quick drain on your battery. Check the current drain using a multimeter. |
3310 water damage | Beef | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-15-2002 22:36 |
Ultrasonic PCB Cleaners for repairing water damaged boards just £75 | logosunlimited | Main Sales Section | 13 | 01-14-2002 11:19 |
V.50 not charging after water damage | bluelights | Motorola Old Legacy (EMMI) | 0 | 01-07-2002 18:25 |
water damaged 5110 | gsmxc | Nokia Hardware & Hardware Repair | 5 | 10-18-2001 16:15 |
3210 *water damaged* no reception | pks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-28-2001 12:09 |
