02-06-2001, 06:32 | #1 (permalink) |
Crazy Poster Join Date: Nov 2000 Location: Sydney, NSW, Australia
Member: 2574 Status: Offline Thanks Meter: 1 | water damaged 5110 |
The Following User Says Thank You to gsmxc For This Useful Post: |
02-07-2001, 03:56 | #2 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Philippines
Member: 1272 Status: Offline Thanks Meter: 3 | all you need is WD40 and silicon contact cleaner. spray it inside the pcb [wd 40] to displace water. 3-5 hours, sparay it with the silicon contact cleaner to displace the WD40. tehn try powering it after 5 hours. if not, bring it to nokia to have some parts changed ------------------ MDR |
02-07-2001, 17:44 | #3 (permalink) |
Freak Poster Join Date: Jun 2000 Location: In front of pc
Member: 1585 Status: Offline Thanks Meter: 15 | hi! use lighter fluid and brush to clean the board. let it dry for a while. repeat procedure until corossion is gone. put soldering paste/flux on chips/discrete devices and use hotair to resolder. let it cool.... do the usual check... regards |
10-15-2001, 03:39 | #4 (permalink) |
Insane Poster Join Date: Apr 2001
Member: 3968 Status: Offline Thanks Meter: 0 | Hello guys, I beg to disagree with the use of WD40 or any oil based substance on the board. By the time you use your hot air rework station, some solders will fall apart when there id presence of oil. Metallurgical properties of lead indicates that lead gets repelled by oil. Anyway, the best recommendation I can give is simply wash the board with soap and running water. Use an old toothbrush and brush the board if necessary. Whatever you do, do not let it dry by itself! Thats the time corrosion occurs if you let it to dry by itself. The best way is to dry it using your SMD rework station with air set to max and heat set to min. Do not use flux. I have used this method on less than 1000 phones but since it never failed me once, I believe you can try it too. Good Luck. Best regards, Muscleman |
10-17-2001, 07:07 | #5 (permalink) |
Member: 1272 Status: Offline Thanks Meter: 3 | [quote]Originally posted by Muscleman:<br /><strong>Hello guys, I beg to disagree with the use of WD40 or any oil based substance on the board. By the time you use your hot air rework station, some solders will fall apart when there id presence of oil. Metallurgical properties of lead indicates that lead gets repelled by oil. Anyway, the best recommendation I can give is simply wash the board with soap and running water. Use an old toothbrush and brush the board if necessary. Whatever you do, do not let it dry by itself! Thats the time corrosion occurs if you let it to dry by itself. The best way is to dry it using your SMD rework station with air set to max and heat set to min. Do not use flux. I have used this method on less than 1000 phones but since it never failed me once, I believe you can try it too. Good Luck. Best regards, Muscleman</strong><hr></blockquote>that's what i do also... now coz coz before, i don't have hot air |
3310 water damage allmost fixed please help! | simfree | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-16-2002 01:28 |
3310 water damage | Beef | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-15-2002 22:36 |
Ultrasonic PCB Cleaners for repairing water damaged boards just £75 | logosunlimited | Main Sales Section | 13 | 01-14-2002 11:19 |
V.50 not charging after water damage | bluelights | Motorola Old Legacy (EMMI) | 0 | 01-07-2002 18:25 |
3210 *water damaged* no reception | pks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-28-2001 12:09 |
