02-27-2010, 09:11 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: pakistan Age: 39
Member: 1019981 Status: Offline Sonork: [email protected] Thanks Meter: 98 | pls healp n70 after one or tow minte |
02-27-2010, 18:55 | #2 (permalink) |
Member: 1019981 Status: Offline Sonork: [email protected] Thanks Meter: 98 | pls replay any body healp me |
02-28-2010, 09:05 | #3 (permalink) |
Member: 1019981 Status: Offline Sonork: [email protected] Thanks Meter: 98 | no body reply me pls reply urgent |
02-28-2010, 16:02 | #10 (permalink) | |
Major Poster Join Date: Jan 2010 Location: above mountain indonesia
Member: 1218241 Status: Offline Sonork: bourouh tuandour Thanks Meter: 20 | Quote:
n 70 ye that the damage to its software that it must have been bermasalah.dan security for your problem please read here http://forum.gsmhosting.com/vbb/showthread.php?t=920409 If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 | |
3110 power off after 10 or 15 mints | nangia khan | Nokia Hardware & Hardware Repair | 10 | 03-22-2010 09:59 |
pls healp me | max009 | Various CDMA/TDMA Cell Phones | 0 | 12-30-2009 19:51 |
n 73 blue lcd pls healp | kashantariq2002 | Nokia Hardware & Hardware Repair | 5 | 09-27-2009 09:01 |
z610i torn of after one or tow munite help | mobayk | Sony Ericsson | 1 | 11-20-2008 19:05 |
x100 after tow mint show fully charging | soy | Samsung Hardware Repair | 1 | 01-21-2007 12:48 |
