what can i do with this 3310? Please help me, i have 3310 without signal (absolutely) phone has no TX and no RX (in manualy search network is result no network) 1. i flashed uploaded new eeprom update faid and reseting 2. i was rehot averything (cobba, ccont PA ...etc) 3. i changed hagar, ccont, antena swith 4. i checked with eeprom tools v4 B-Phraks and everything was checked OK. what can i do with this please? |
Read old posts there are many many solution here...and we are just fed up with writing the same thing over and over again..!!!!!!!! WBR Syed |
I know .. i read many posts and reapir many phones with these sol.. but with this i dont know. |
if u have osilloscope then check TX/IQ signal from cobba first if not ok then check supply voltage to cobba if ok the cobba faulty or brocken soldering under it ...., try reball/change ..., then go to next step ...., check 26 mhz crystal ...., deviation must be less than 100 hz if more than 100 hz then 26 mhz crystal faulty ....,( u need frequency counter) Now post the result and then i will tell u what to do ... Good Luck ------------------ MrHazeem |
Mr.Hazeem ... many thanx for your help i will try your solution and write back effect. |
change cobba |
please test your speaker sound is it normal/ noisy or very soft when press keypad i have my own solution if same as mine |
i changed crystal .. nothing than cobba .. nothing a got original cobba back and now CS. i can flash and reseting.. everything works but still CS. maybe i hot out something :( yes man speaker was soft. |
@ Kamilll, CS, bcos of the cobba that u put back on is faulty or the soulder ball shorted,, u diffinately need a good cobba, it might fixed both CS and reception .. good luck |
what is the CS can someone explain me? if you dont mind Best regards afyf |
cs mean contact service |
@Kamilll did u get your phone fixed??? |
there is a small resistants on the top of the cobba try to resold all of it |
please soft your contact service than post here . if speaker stiil noisy or soft .you need to take out one of the small chip. |
