12-24-2004, 12:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Islamabad, Pakistan Age: 42
Member: 48857 Status: Offline Thanks Meter: 31 | what is the diff in pcbs |
12-28-2004, 21:00 | #2 (permalink) |
Junior Member Join Date: Apr 2003 Location: C-Block Age: 44
Member: 26278 Status: Offline Thanks Meter: 0 | Actually, there is no difference. You should pay attention on board revision. They are, for example, UB4-08,09,10,11 or 12. PCB UB4-08 is for an old 3310. It does not contain adititional keypad spots. These spots are used for 3410. Difference between 3310 and 3330 is a flash IC and it's capacity. Difference between 3310 and 3315 is eeprom data. May be you have noticed that 3310 and 3315 do use same firmware - NHM-5. Differneces between 3330 and 3410 are - frimware, eeprom content, LCD. Hope this will help you. WBR Phase |
12-28-2004, 21:14 | #3 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Neptune Age: 22
Member: 58599 Status: Offline Thanks Meter: 2 | also pcb have diff coluours 3310 is lightly yellow, 3330 is green also 3410 has more keypad bottons.. hope it helps....Also write a fresh eeprom files to phones... with correct mcu and ppm..I advice u use geo flasher or rolis 4.79 build... WBR |
02-22-2005, 21:23 | #8 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 37
Member: 62336 Status: Offline Thanks Meter: 115 | Quote:
What is the flash in Spanish for the E250? | carlosmontes | NSPRO | 0 | 11-30-2008 21:27 |
What is the data in the eeprom play the role for? | subaru | Old Ericsson Phones & Sony Phones | 3 | 06-07-2003 12:10 |
what is the adress in pony for field 251?? | xchris | Infineon C16X M51 & ARM7 M52 BASED | 1 | 01-29-2002 06:46 |
