Old 11-09-2007, 18:15   #1 (permalink)
Member: 609370
Thanks Meter: 13
What Is The Role Of Smps Ic N4200 In N70?
In N70 Smps Ic N4200 Has 10 Pins.
Two Pins R Input From Battery +ve
Two Pins R Output Vcorea=1.4v (one Doubt Here Tahvo Has Also
A Power Outut Named Vcore=1.4v,is Both R Same Line?)
Power Output Voltage R Same 1.4v.but A Small Difference In Output Names.smps Output Name Vcorea And Tahvo Output Name Vcore.
I Think Both Above R Connected Each Other.i Have Seen Many Shorting Methods For N70 Without Smps Ic.then How Work Omap Without Smps Output?
Old 11-09-2007, 18:40   #2 (permalink)
y2y
y2y's Avatar
Member: 166000
Thanks Meter: 26
No. that both voltage are not connected each other, as u mentioned before : Vcore came from tahvo and VcoreA came from smps ic.
The method that shorting VcoreA with Vcore was used because both have the same voltage, tahvo will release Vcore when he get voltage from battery and control from retu.
Old 01-10-2008, 08:13   #3 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
@ Mr.zone2
can give me a schematic of SMPS ??
GsmJoman
Tc
Old 07-05-2012, 11:22   #4 (permalink)
Member: 1768490
i have the same problem
what is the solution of damage Potato BOX ???? ..::MOBILES::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 17:03
What is the cause of hate for everyone in the MXKEY hamada-almasry MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-03-2010 06:36
What is the role of program ufsx002 Nokia Base Band 5 ( BB-5 ) 1 01-05-2009 10:41
what is the use of this ic in n70 navin71 Nokia Hardware & Hardware Repair 2 09-30-2007 13:59
What is the "name" of ST locked flash IC? pavlin BF, BG, TH, BHx Series 0 01-15-2003 09:25
Page generated in 0.17669 seconds with 10 queries
