02-29-2004, 15:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | wired 8250 rssi -56 no network. 8250 with no network at all. rssi is -56. try to upgrade-downgrade, full flash, same result. it,s from cpu problem ? where ? thanks n w.b.r. |
03-01-2004, 18:46 | #3 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Cyprus Age: 42
Member: 15149 Status: Offline Thanks Meter: 61 | if net moniter showing NSPS ( no signal power save) ! then it mean Hager to COBBA then IP/QP signal is not given ! or COBBA can not do good demod that wave ! so first you have to see that IP/QP wave is ok or not ! then if not, go to check VRX from CCONT supply to Hager ! also you can try to measuer that TX power out going level and frq is ok or not ! if TX frq and level is ok, then it mean COBBA is ok, and PLL loop from ahger to VCO is OK! then continue, that you have to check that antenna switch , saw fileter to Hager ! if all is ok, then you go to check MAD to Hager via SDATA, SENA, SCLK ! you might need have oscilliscope to "see" ! |
03-01-2004, 19:04 | #4 (permalink) |
Member: 14578 Status: Offline Thanks Meter: 831 | thank you very much Mr. willy, i hope that only you solve this problem for me. and i think now i can solve this phone by your $$$ help. @ZetMen, thanks for detail. thanks again you2. W.B.R. |
2680s 56.17 unlock ok but no network | nguyenhuu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 09-06-2009 07:21 |
3310 no network in 3 seconds.RSSI -122 | .::AkhavanGSM::. | Nokia Hardware & Hardware Repair | 3 | 08-02-2004 01:06 |
8250 no network | VinhHai | Nokia Hardware & Hardware Repair | 8 | 10-20-2003 13:54 |
8250 no network!! | fadi79 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 11-17-2002 22:49 |
6210 v5.56 no network - help ! | Spellbound | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 11-14-2002 18:23 |
