Old 03-29-2012, 06:45   #1 (permalink)
Member: 909521
Sonork: shabee
Thanks Meter: 28
X2-00 Charging not supported
X2-00 in switch on possition charging not supported in off position can charg
Old 03-29-2012, 09:55   #2 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 154
Nokia X2-00 Charging not supported solution
File Type: jpg Nokia X2-00 Charging not supported solution.jpg (91.1 KB, 2619 views)
Old 03-29-2012, 10:02   #3 (permalink)
Member: 909521
Sonork: shabee
Thanks Meter: 28
Bro i had replaced this components but same problem i was flashed also but in off possition is working only not chrging in on possistion
Old 05-14-2012, 11:53   #4 (permalink)
Member: 612010
Thanks Meter: 5
x2 charging not supported
i have water damage x2 phone
phone is working perfactly but when insert charging than it show charging not supported
i change component as above but problem still same as before
Old 05-15-2012, 08:42   #5 (permalink)
N.C.Erepola's Avatar
Member: 1615710
Sonork: 100.1647890
Thanks Meter: 260
Change Betty IC brother
The Following User Says Thank You to N.C.Erepola For This Useful Post:
Old 05-15-2012, 11:46   #6 (permalink)
kathirmobiles's Avatar
Member: 1591177
Thanks Meter: 85
bro try post result
Old 05-18-2012, 06:47   #7 (permalink)
Member: 612010
Thanks Meter: 5
sir i replace all this component but not success. i replace this component from nokia 1200 r2158 and r2159
is this supported this 47k component or not ???
pls
where can i found this 47k btemp ???
Old 05-18-2012, 08:01   #8 (permalink)
Member: 1760482
check your data cable it may have lost connections
Old 07-08-2012, 10:27   #9 (permalink)
..::RAJA-SOFT-INDORE::..'s Avatar
Member: 1702670
Sonork: 100.1623908
Thanks Meter: 1,667
abe gel chode tere baap ne banai hai kya betery ic
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-02-2000 22:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Page generated in 0.22311 seconds with 10 queries
