10-09-2012, 04:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | x2-02 problime??? |
The Following User Says Thank You to niaz muhammad For This Useful Post: |
10-09-2012, 04:24 | #2 (permalink) |
No Life Poster Join Date: Jul 2012 Location: Pakistan Kpk Bannu
Member: 1780311 Status: Offline Sonork: 100.1615434 Thanks Meter: 124 | download latest Flash file.........version11.79 Last edited by sami ullahkhan; 10-09-2012 at 04:31. |
The Following User Says Thank You to sami ullahkhan For This Useful Post: |
10-09-2012, 04:31 | #3 (permalink) |
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | i use letest ver but same problime.............. ver 11.79 |
10-13-2012, 14:24 | #11 (permalink) |
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | this is log MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0854F9A Using device: USB Phonet and HTI, FW ver: 00.50, SN: 01006465 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35243005675224 RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35243005675224_ back.RPL) Processing file: rm694__11.84.mcusw Downloading item CODE:rm694__11.84.mcusw_ebl_psi.fls, num block: 4, size: 26.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.359 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.359 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.500 s Erasing area 0x40280000-0x41B7FFFE ...OK Programming completed in 36.297 s Checksum verified (0xB615) Processing file: rm694__11.84.ppm_m_a Downloading item CUSTackage_m_a.ppm_ebl_psi.fls, num block: 1, size: 4.25 MB Erasing area 0x41C00000-0x4204033E ...OK Programming completed in 6.687 s Checksum verified (0x40FC) Processing file: rm694__11.84.image_m_a_059J701 Downloading item CUSTackage_m_a_059J701.image.fls, num block: 1, size: 13.75 MB Erasing area 0x42300000-0x43E1FFFE ...OK Programming completed in 22.141 s Checksum verified (0x1F44) Total time for flashing process(boot+erase+write) was 9 min 17.672 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 627ACFB Verifying communication to device OK. Phone type: RM-694 (X2-02) SW version: V 11.84 13-09-12 RM-694 (c) Nokia Imei plain: 35243005675224-2 Product code: 059D1V1 Language Pack: - not available. Imei net: 35243005675224 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
