Old 08-03-2008, 10:14   #1 (permalink)
shok9992000@yah's Avatar
Member: 578941
Thanks Meter: 108
6085 LCD problem
friends i have two 6085 with same problem that is ,both lcd of inner & outer r not working they r in blank position.
1. I have changed flex
2. I have changed both lcd ic
& i found that after giving some heat it works perfectly for some time but after that it comes back to the same condition, I cant recognize the problem. is there any solution, plz help
The Following User Says Thank You to shok9992000@yah For This Useful Post:
Old 08-03-2008, 16:47   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
reball rap but be careful my friend
Old 08-03-2008, 17:09   #3 (permalink)
Member: 578941
Thanks Meter: 108
could it be rap's problem
Old 08-03-2008, 17:18   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
yes data line of lcd goes through emif filters to rap , check schematics you can find it yourself
good luck
Old 08-03-2008, 17:26   #5 (permalink)
Member: 578941
Thanks Meter: 108
what if i reflow rap
Old 08-03-2008, 17:36   #6 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
" bro tell me in yes or no, when u fixed new ics wt happened dipsplay worked normally or not,thanx"
Old 08-03-2008, 17:37   #7 (permalink)
Member: 706300
Thanks Meter: 147
re:
" if applying more heat will put the unit in big problem,thanx"
Old 08-03-2008, 17:40   #8 (permalink)
Member: 706300
Thanks Meter: 147
re:
good luck
" yah data line passes through to ic, thanx"
Old 08-03-2008, 18:18   #9 (permalink)
Member: 578941
Thanks Meter: 108
when i changed ics it work perfectly for 4 hours
Old 08-04-2008, 06:55   #10 (permalink)
Member: 706300
Thanks Meter: 147
re:
" bro change ic once more & watch the result if again same problem it means when u r applying heat on pcb the rap portion do get heated & results in working of display so apply a gentle heat on rap,thanx"
Old 02-23-2009, 14:11   #11 (permalink)
Crazy Poster
Member: 122331
Thanks Meter: 10
aca le subo las imagenes de lcd y display repair
6085 big problem kami1987 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 13:42
6085 strange problem with lcd fethi Nokia Hardware & Hardware Repair 0 07-30-2009 22:51
6085 lcd salution here ..::ohm::.. Nokia Hardware & Hardware Repair 5 02-23-2009 16:32
6085 lcd???? Destructor Nokia Hardware & Hardware Repair 1 09-30-2008 08:26
Nokia 6085 Lcd Problem !!!!!! albarka network Nokia Hardware & Hardware Repair 6 03-26-2008 11:44
Page generated in 0.24537 seconds with 10 queries
