Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Universal GSM Software
Universal GSM Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers...
Old 12-10-2019, 14:04   #1 (permalink)
Member: 2160706
Thanks Meter: 48
[TOOL][Windows] APK Easy Tool 1.56 / 1.57 beta-1 (29 nov. 2019)
Apk Easy Tool is a lightweight application that enables you to manage, sign, compile and decompile the APK files for the apps you are working on.
Features:
Decompile/Compile
Decomile and compile APK, DEX and JAR files, with SPACE, symbols and germany, danish, swedish etc... characters support. Can cancel during operation
Sign/Zipalign
Signing and ZipAligning of APK/JAR files. Can cancel during operation
Extract/Zip APK
Extract and zip APK with 7z Compression-level 0-9. Can cancel during operation
APK Infomation
Show APK infomation with icon using aapt dump badging and link to Play Store
Framework
Install your framework and manage framework paths
Log output
View your logs to find errors. Set date to view your previous logs
Sided log output is only available for higher resolution with 1250 width and above.
Options
Change options of tool, decompile, compile, sign and zipalign. Options: Java heap, Apktool version, apksigner version, directories, java path, Windows explorer integration, remeber window position and more
All options and textboxes are saved as config.xml and will load on launch
Quick options on main.
Drag and drop
Drop APK, DEX, JAR files and Decompiled folder on buttons to perform actions. Drop outside buttons to select/open as file/folder
Apktool.jar version selection
Can switch to other versions of apktool.kar on options
Add other apktool.jar in "Apktool" folder
Shortcuts
4 buttons to open work directories of decompiled APK, compiled APK, extracted APK and zipped APK
Jumplist shortcuts
Do actions by just right-clicking on APK file and choose the following options, decomile or compile APK, DEX, and JAR files, Zipalign APK, Check align, Sign APK and Install APK.
Download
The Following 4 Users Say Thank You to ffzerob For This Useful Post:
Old 09-14-2020, 22:11   #2 (permalink)
Member: 2967731
If all is need is just APK decompilation, you can use online decompiler without installation.
Page generated in 0.18666 seconds with 8 queries
