Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Universal GSM Software
Universal GSM Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers...
Old 08-11-2011, 10:52   #1 (permalink)
trust4eve83's Avatar
Member: 1269056
Thanks Meter: 1,114
Arrow Huawei Modem Unlocker
download ::: Huawei-Modem-Unlockerv5.8.1.rar - 4shared.com - online file sharing and storage - download
enjoyyyyyyy
mohsin from south africa
The Following 12 Users Say Thank You to trust4eve83 For This Useful Post:
Old 08-11-2011, 10:56   #2 (permalink)
GsmSolution.'s Avatar
Member: 1388679
Sonork: 1597516:GsmSolution
Thanks Meter: 2,757
what modem is supported with this?thanks
br
Old 08-11-2011, 11:10   #3 (permalink)
kapilpanday's Avatar
Member: 951882
Thanks Meter: 323
whr is e1732 solustion brother ?
Old 08-11-2011, 12:42   #4 (permalink)
nura1335's Avatar
Member: 481744
Thanks Meter: 30
Not working bro.
100%%%%%%%%%%%%%%% Not working bro.
Old 08-11-2011, 14:04   #5 (permalink)
Member: 1269056
Thanks Meter: 1,114
what is not working bro link or soft...?
Old 08-12-2011, 19:49   #6 (permalink)
Cheater -Don't Deal with him-
Member: 1294693
Sonork: 100.1591739
Thanks Meter: 483
downloaded software
wil check and post results
anyway thanks
Old 08-13-2011, 06:44   #7 (permalink)
Member: 631452
Thanks Meter: 6
man you guys are really fooling people
Old 08-13-2011, 10:31   #8 (permalink)
Member: 1634244
Thanks Meter: 143
does this soft can reset lock counter back to default.
Old 08-13-2011, 11:16   #9 (permalink)
hasanmh's Avatar
Member: 1236034
Sonork: 100.1592650
Thanks Meter: 463
yes it does . i have tested it by my self
Old 08-13-2011, 21:40   #10 (permalink)
Crazy Poster
Member: 80227
Thanks Meter: 2
bug? -->
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at HuaweiMDM.hua.detectmodem()
   at HuaweiMDM.hua.hua_Load(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3603 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///E:/download/gsm-forum/Huawei%20Modem%20Unlocker.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Old 08-13-2011, 23:03   #11 (permalink)
Crazy Poster
Member: 80227
Thanks Meter: 2
Don't forget you need to charge the battery before the device will be recognised!
You need to press the dial key at the top of the E5830 to put in diag mode before flash upgrading.
Which firmware is most unlocked though?
WLCGCPU11020_UPDATE_ALL_NO_QCSBL_V100R001C00B112SP 05_USB.exe
^ quite open but no sim functions, can't change APN. Version 666.something
E5838Update_716.11.17.07.108SP02.exe
^ now testing. v716.something...
more info:
http://www.shadwell.eu/paul_shadwell...-firmware.html
Old 07-09-2012, 12:51   #12 (permalink)
Member: 1308472
Sonork: mohd_nadeem231
Thanks Meter: 10
ir showing password ad username
what isteh password
Old 07-15-2012, 16:44   #13 (permalink)
Member: 1760941
Sonork: 100:1616842
Password needed
4shared.com is requesting a password to download the file.
Old 07-15-2012, 16:46   #14 (permalink)
Member: 1760941
Sonork: 100:1616842
Old 07-15-2012, 17:25   #15 (permalink)
Member: 1368264
Thanks Meter: 13
http://****************/universal/Huaw...ckerv5.8.1.rar
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.22880 seconds with 9 queries
