Motorola Old Legacy (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families. |
01-09-2002, 21:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | I need felx table for startac 130!!!!! |
01-10-2002, 18:20 | #2 (permalink) |
Member: 3381 Status: Offline Thanks Meter: 1,171 | I have this problem to resolve: when i make an SMS and try to send message i can't acces in index book for search the name but i have to make directly the number of phone.<br />I would appreciate one suggestion of yours.<br /> <img src="wink.gif" border="0"> |
01-12-2002, 14:30 | #4 (permalink) |
Freak Poster Join Date: Nov 2000 Location: Russia, Moscow Age: 45
Member: 2544 Status: Offline Thanks Meter: 5 | Fro Janus page<br />002 0 Keylock (press # & * together) <br />003 0 MENU-PhoneBook(Personal Numbers) (add to top level) <br />004 1 MENU-Messages <br />005 0 Mute On/Off (MENU, during call) <br />006 1 Show complete menu of Call Related Features and Messages <br />007 0 MENU-"Arrows" <br />008 0 Select Phone Line <br />009 0 Last Ten Calls (Call Related Features) <br />010 1 Restrict My Phone Number <br />011 1 Call Diverting <br />012 1 Divert When Unavailable <br />013 1 Detailed Diverting <br />014 1 Divert Voice Calls <br />015 1 Divert All Voice Calls <br />016 1 If Busy <br />017 1 If No Answer <br />018 1 If Not Reachable <br />019 1 Divert Fax Calls <br />020 1 Divert Data Calls <br />021 1 Cancel All Diverting <br />022 1 Call Waiting <br />023 1 Call Barring <br />024 1 Bar Outgoing Calls <br />025 1 Bar Incoming Calls <br />026 1 Change Bar Password <br />027 0 Call Restrictions <br />028 0 Restrict Incomming Calls <br />029 0 Phone Number Length <br />030 0 Keypad Dialing <br />031 1 Call Voicemail <br />032 1 Received Messages <br />033 1 Cell Broadcast <br />034 1 Message Settings <br />035 1 Message Alert Tone (7500/8200 Only) <br />036 1 Voicemail Number <br />037 1 Incoming Call Alert (7500/8200 Only) <br />038 0 No Alert (7500/8200 Only) <br />039 1 Vibrate Only (7500/8200 Only) or VibraCall On or Off(In Quick Access Menu, 2.75v w/VibraCall) <br />040 1 Adjust Ring Volume <br />041 1 Lock Now <br />042 1 Automatic Lock <br />043 1 Change Unlock Code <br />044 1 Require SIM Card PIN <br />045 1 Change SIM PIN Code/Export PIN for Storage <br />046 1 New Security Code <br />047 1 Extended Menus <br />048 1 Language Selection <br />049 1 Automatic (Language Selection) <br />050 0 Change Greeting <br />051 1 Battery Saving Mode <br />052 1 Select Keypad Tones <br />053 1 Phone Status <br />054 1 Status Review <br />055 1 Master Reset <br />056 1 Master Clear <br />057 1 Available Networks <br />058 1 Network Search <br />059 1 Registration Preferences <br />060 1 Frequency Of Search <br />061 1 Preferred Networks <br />062 1 Add Network To List <br />063 1 Show List Of Networks <br />064 1 Find New Network <br />065 1 Show Last Call (7500/8200 Only) <br />066 1 Resettable Call Meters (7500/8200 Only) <br />067 1 Set Audible Call Timers <br />068 1 Single Alert Timer <br />069 1 Repetitive Timer <br />070 1 ** 1 = Register write lock !!!! (no effect on newer phones) <br />071 1 Show Meter During Calls (7500/8200 Only) <br />072 1 Set Meter Format (7500/8200 Only) <br />073 1 Set Call Cost Rates (7500/8200 Only) <br />074 1 Lifetime Meter <br />075 1 ?Mute Car Radio <br />076 0 ?Mute Car Radio <br />077 1 ?Auto Answer <br />078 1 ?Mute Car Radio <br />079 1 ?Automatic Handsfree <br />080 0 ?Aus Alert <br />081 1 Find Entry By Name <br />082 1 Find Entry By Location <br />083 0 Show Services <br />084 0 Enter My Phone Number (7500/8200 Only) <br />085 0 Show My Phone Number (7500/8200 Only) <br />086 1 Add Entry <br />087 1 Check Phone Capacity <br />088 1 Check SIM Capacity <br />089 1 Prevent Access <br />090 1 Edit Name (My Phone #) <br />091 1 Edit Number (My Phone #) <br />092 1 MENU-Call Related Features <br />093 1 MENU-Phone Setup <br />094 1 MENU-Network Selection <br />095 1 MENU-Call Meters <br />096 1 ?MENU-Accessory Setup <br />099 0 Periodic Search <br />100 1 Continuous Search <br />101 1 Slow Search <br />102 1 Medium Search <br />103 1 Fast Search <br />104 0 MENU-PhoneBook <br />105 0 MENU-PhoneBook (add to bottom level) <br />106 0 MENU-Messages (add to bottom level) <br />107 1 Divert All Calls <br />108 0 Copy SIM Memory <br />109 0 Divert to Voicemail or Other Number <br />110 0 Edit Number (Direct Dial Key) <br />111 0 Edit Name (Direct Dial Key) <br />112 0 Direct Dial Key (Phone Setup) <br />113 0 MENU-Eng Field Options <br />114 1 Ring Or Vibrate <br />115 1 Set Ringer Tone <br />116 1 Vibrate Then Ring <br />123 1 Enable Clock / Show Time and Date / Set Time and Date / Set Time Format <br />124 1 Talk and Fax <br />125 0 Talk and Fax Next Call <br />126 1 Erase All Numbers (Last Ten Calls) <br />127 0 MENU-PhoneBook <br />128 1 Personal Numbers <br />129 1 Show Services <br />130 1 Last Ten Calls <br />131 0 My Phone Number(s)(Phone Book|Personal Numbers) <br />132 1 Fixed Dialling <br />133 1 One-Touch Dial Setting <br />134 0 Closed User Group <br />135 1 Outgoing Message <br />136 1 Message Editor <br />137 1 Message Settings(w/o Voicemail Number) <br />138 1 Change SIM PIN2 Code <br />139 1 Show Call Charges <br />140 1 Show Call Timers <br />141 1 Set In-Call Display <br />142 1 Call Charge Settings <br />143 1 Set Total Charge Limit <br />144 1 Set Charge Type <br />145 1 Disable change Phone Book Options menu to Personal Numbers <br />148 0 Ringer On or Off(No Vibrate phones) <br />149 1 Show Battery Meter <br />152 1 Dansk <br />153 1 Nederlands <br />154 1 English <br />155 1 Suomi <br />156 1 French <br />157 1 Deutsch <br />158 1 Greek <br />159 1 Magyar <br />160 1 Italiano <br />161 1 Norsk <br />162 1 Portuguese <br />163 1 Spanish <br />164 1 Svenska <br />165 1 Turkish <br />168 1 Signal Strength Indicator <br />171 0 Thai <br />172 0 Tieng Viet <br />173 0 Bahasa Malaysia <br />174 0 Bahasa Indonesia <br />175 0 Filipino <br />176 0 Simplified Chinese <br />177 1 Don't display menu name <br />179 0 Keypad Guard <br />184 1 Call Diverting(New style) <br />185 1 Enable custom Quick Access Menu <br />187 0 Key Answer Only <br />189 1 My Phone Number(s)(Phone Book) <br />191 1 Enable EFR on DSP 71.xx or higher <br />193 0 Set Ringer Tone 2 <br />195 1 Fax(Outgoing Message Type) <br />196 1 X400(Outgoing Message Type) <br />197 1 Paging(Outgoing Message Type) <br />198 1 E-Mail(Outgoing Message Type) <br />199 1 ERMES(Outgoing Message Type) <br />200 1 Voice(Outgoing Message Type) <br />202 1 Polski <br />203 0 Change Band <br />204 0 Change to 900 <br />205 0 Change to 1800 <br />206 0 Change Band (in Shortcut Menu) <br />207 1 VoiceNotes(cd928/938 Only) <br />208 0 (Add 3 trem to Quick Access Key) <br />209 0 Export PIN delete <br />211 0 Record VoiceNote <br />213 0 Automatic Inactive Select Phone Line 1/2 on 900 MHz Band <br />216 0 Cestina(Language) <br />217 0 Complex Chinese <br />218 0 Input Method Selection(cd928+ S/W AB.50.03 Support CKE(Chinese Keypad Entry)) <br />219 0 Pin-Yin <br />220 0 Stroke <br />221 0 Smart English <br />222 0 Multi-tap <br />223 0 Bo-po-mo-fo <br />224 0 Greeting Tone(StarTAC S/W 64.09.09 or higher) <br />227 0 Romanian <br />228 0 Lithuanian <br />229 0 Russian <br />231 0 Enable Flip function <br />232 0 Enable flash light <br />233 0 Voice Dialling(Menu only, no function) <br />234 0 Quick Access Setup/Add or Edit Voice Tag (if 233 enabled)(cd928/938 S/W AB.04.14 or higher) <br />236 1 Delayed Power off(cd928/938 S/W AB.04.14 or higher) <br />239 1 Power off tone(cd928/938 S/W AB.04.14 or higher) <br />241 0 (If set to 1 Phone display poor greeting) <br />243 0 Adjust Colour(Menu only, no function) <br />244 0 (If set to 1 Phone while power off) <br />253 0 Change to 1900(cd938 Only) <br />254 0 Change to 900/1800(cd938 Only) <br />255 0 Change Mode (Auto Select/Digital Only/Analog Only) <br />256 0 Change Mode (Quick Access Menu) <br />259 0 Bulgarian(cd938 Only) <br />260 0 Hrvatski(cd938 Only) <br />261 0 Eesti(cd938 Only) <br />262 0 Latviski(cd938 Only) <br />263 0 Srpski(cd938 Only) <br />264 0 Slovensky(cd938 Only) <br />265 0 Slovensko(cd938 Only) <br />266 0 Ukrainian(cd938 Only) <br />272 0 Send Message|Enter Number/Find Entry By Name/Find Entry By Location <br />273 0 Memory Monitor <br />276 0 Set Message Alert Tone(cd938 Only) |
01-12-2002, 17:43 | #5 (permalink) |
Member: 3381 Status: Offline Thanks Meter: 1,171 | tanks i have flashed the phone whit this version but don't work. <img src="wink.gif" border="0"> <br />I have resolved this problem whit clone card.....and I now smile <img src="smile.gif" border="0"> <img src="wink.gif" border="0"> <FONT COLOR="#ffff00" SIZE="1">[ 12 January 2002 18:05: Message edited by: Pandemonio100 ]</font> |
Needed testpoint picture to StarTAC 130 or SM | layder | Motorola Old Legacy (EMMI) | 0 | 05-23-2004 12:31 |
Need fdf file for startac 75 | GSMBlade | Motorola Old Legacy (EMMI) | 0 | 04-21-2004 14:39 |
Help!!!The circuit is necessary for StarTac 130 | BABAH | Motorola Old Legacy (EMMI) | 0 | 04-04-2004 16:57 |
i need lang pack for startac 130 | DEEJAYBIALY | Motorola Old Legacy (EMMI) | 0 | 09-16-2003 15:03 |
