v3688 network problem when I turn it on network signal is present and after 20 sec or when i try to make a call it's gone,and then comes back,and then again lost signal,what is problem here,tell your solutions |
Pls measure the battery side 's 26 MHZ crystal clock, and check the Magic I.C if it's working good you have to move the metal cover. |
anybody else have some solutions |
bert can you explain where are these two things that you are talking about above,and I have one question,on the battery side on the top of PCB are 3 transistors,I wan't to know somethinh about that in the midlle,what is it used for....THANKS |
