Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
10-21-2006, 10:08 | #1 (permalink) |
Junior Member Join Date: Oct 2006
Member: 375100 Status: Offline Thanks Meter: 0 | uNlock V3r with cable usb Can i unlock my v3r with the usb cable ? i Made the test point and try to unlock with p2keasy 3.7 and 3.9 , i get error : Connecting to phone ... Connected to: 'Motorola Flash' Connected OK Bootloader version: 0300 Sending loader to phone ... Loader sent OK. Read Flash ID ... Flash ID: 20000E88 Unlocking ... 5 minutes pass i retire the usb cable and get this : Error reading PDS VARS (2) ERROR: Unlock failed thanks all |
10-21-2006, 14:09 | #7 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Portugal Age: 41
Member: 241933 Status: Offline Thanks Meter: 77 | Hi again...normaly i use p2k3.9 cracked to unlock v3r and other types ..... try this tracky connect usb to v3r than do TP and connect the battery...open p2k3.9 and select v3r and do unlock...when appers a mensage to disconect TP click OK but DON´T remove TP..... if this no result try this press *;#+powerOn... the phone will be in boot mode ....do the TP and try again..... Even this no result ....than try flash to a new version firmware P.S. If u can't unlock the phone leave him ....before u kill him... |
10-21-2006, 14:36 | #8 (permalink) |
No Life Poster Join Date: Jan 2005 Location: PT Age: 40
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | post the version of yours boot loader do you make the testpoint correct check it and reply try to flash the phone with a unlocked version full flash |
10-21-2006, 20:16 | #10 (permalink) |
Member: 241933 Status: Offline Thanks Meter: 77 | I only use 1 simple usb cable without any box ,only p2k 3.9.... and i using xp sp2.... try use other pc ..... i really haven't more solutions for that case. |
6210s-1 unlocked succefly witk DKBB5 TRK Unlocker with cable usb | leader_gsm | BB5 Box by D.K. | 5 | 02-06-2011 12:45 |
unlocking s65 with any USB-Cable? | dani84 | S-Gold Based Phones | 3 | 02-05-2008 22:21 |
can i unlock D407 with P207 usb cable ? | cellularman | NSPRO | 15 | 10-02-2006 12:41 |
cant unlock V3r with SmartMoto 1.21 | dhru_21 | Smart-Clip | 4 | 06-07-2006 17:23 |
i cant unlock C350 with cable usb C33X | flechazo | Motorola P2k | 3 | 09-27-2003 17:28 |
