How to repair v3 family with bootloader only I've encountered three units already with only bootloader on screen everytime you turn it on. I already do repair pds and fullflash still the same or even worse don't turn on. does anybody know how? By the way i have smartclip and usbsmart with p2k tool as repair gadgets. |
Use MSS4 do steps: 1- PDS repair. 2- Flash phone with full flash file. 3- Install bootloader. |
I got this way from howard forum http://rapidshare.de/files/13264213/...m07E0.zip.html Tested to work on BL 07.E0 or below .. yeay! 1) download shxcodec and extract 2) click add .. choose 07e0.bin .. leave the code group blank and enter 03FD0000 in start address (this will show as ramdownloader) 3) click add again .. choose 10010000 (or yourPDS.bin) ... put 6 in code group and 10010000 in start address (this will show as CG6) 4) combine the file (put .shx extension) 5) flash the file like normal flash NOTE : Do not use RSD to flash this file ... use flashbackup or mff/pst Then .. upgrade the phone back to 0823 I never used it but you can try it. TIA |
hi man use smart clip flash full flash .smf over write bootarea all is ok if phone can;t connect use test point then flash |
Share us what u see in flash mode screen .. Mey Be u have hardware proplem ;) ;) B.R AyMaN gHoSt |
just like what you see when you press *,# and power on |
