Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
03-13-2006, 05:08 | #1 (permalink) |
Junior Member Join Date: Mar 2004 Location: Viet Nam Age: 53
Member: 59355 Status: Offline Thanks Meter: 0 | Motorola V3 call drop But I don't underttand this problem exactly. I have some experience, pls help me |
04-04-2006, 12:58 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | Problem is not in PA or somwhere else, if you look carefully it does like you close cover. So in fact problem is: I phone working in perfect conditions, like it selected 19, 15 and etc chanels, and TX level not reaching 25-33 db all works ok, but if it selects in ex. 5 chanel, and powers it's PA to max level, your cover probe will think that cover is closed because PA's generating to strong signal, so it will drop call, and when PA activity ends, no distortion signal will receive probe, and it will think that cover is opened. So problem is in that circuit with cover probe, like in Samsung E530, Nokia 6170, because theese phones have same problems. Motorola claims that solution is latest firmware, but - sh.t, tryed, not working. In nokia helped some hardware modifications, in Samsung helped probe shielding. Will try some V3 to repair and will post solution if need'ed. B.R. Alkapone |
04-14-2006, 18:01 | #4 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: New York City, USA Age: 58
Member: 56365 Status: Offline Thanks Meter: 28 | Quote:
http://forum.gsmhosting.com/vbb/show...20&postcount=3 Regards, JOHNNY. | |
04-15-2006, 00:27 | #5 (permalink) |
Member: 19265 Status: Offline Thanks Meter: 92 | O, sorry, forgot ... Yes, solution found, and it is hall sensor faulty. You have to look at it, and if there is AA1 markings on it - faulty part (factory fault), you need to change it with 515808 (dont remember exact numbers, but just need to be not AA1), and that's all. B.R. Alkapone |
nokia 2112 in call drop, call ended, no outgoing | ashish mobile | Nokia Hardware & Hardware Repair | 0 | 05-02-2009 07:53 |
Motorola V3 Flashing, Rogers to Orange Firmware – Distortion on Calls now | E2EK1EL | Motorola P2k | 0 | 06-30-2008 07:33 |
moto A920 . call drop /call failed | celcom | Motorola P2k | 0 | 01-10-2005 11:42 |
A35 can't make call, call dropping | pali | Siemens Hardware Repair Area | 1 | 06-03-2002 04:51 |
8210 ... & ...6210 weak signal problem..call drops...sinal drop | PTR999 | Nokia Hardware & Hardware Repair | 3 | 04-17-2002 14:06 |
