Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola P2k
Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200
C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980
E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070
P-Series: P280
T-Series: T280,T720,T721i,T722i
V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050.
other-Series: like L6,L7,U6.
Old 09-09-2008, 05:42   #1 (permalink)
Member: 606522
Question Motorola v3, full network signal, call failed. help!
I have a moto v3, full network signal, network unlocked, not call barred, but when calls, shows call failed, and also cannot sent out messages. help, Thank you.
Old 09-09-2008, 15:55   #2 (permalink)
michel.tissier's Avatar
Member: 736073
Thanks Meter: 81
first of all try to do a master reset , if that don't work
try to full flash with rsd any box that you have (if you have any)
if this don't work with some tool repair pds
regards!!
Old 09-10-2008, 02:43   #3 (permalink)
Member: 606522
regards!!
I tried all the methods by smart-clip, still doesn't work. still thank you. Any other solutions?
Old 09-10-2008, 03:40   #4 (permalink)
Member: 857496
software_hardware_pa
Old 09-10-2008, 04:03   #5 (permalink)
Mr.Cool_79's Avatar
Member: 245808
Thanks Meter: 7
its the power amplifier is the problem try to re-heat... take care when reheating my friend...
Old 09-10-2008, 04:23   #6 (permalink)
mbcommunication's Avatar
Member: 116918
Sonork: 100.1590386
Thanks Meter: 559
What network SIM are you trying to use if it is Vodafone it could still be barred as it will not show no service will still seem to have full network and show Vodafone on the screen but will not allow calls or sms
Old 09-10-2008, 05:43   #7 (permalink)
.::kabir::.'s Avatar
Member: 638416
Sonork: 100.1591787
Thanks Meter: 1,113
after repair you flash another flash file ,,, some time softwer problem,,,
Old 09-10-2008, 13:14   #8 (permalink)
Member: 736073
Thanks Meter: 81
hardware problem , check it
good lock!
Old 09-13-2008, 07:47   #9 (permalink)
Registered User
Member: 287014
Thanks Meter: 28
Power Amplifier Chip Problem ( PA) Change it
[IMG] code is Off
Samsung e 251 full network but call failed yusufali786 Z3X-Team Products 2 02-22-2010 20:36
N81 shows full network but call failed, help! N761 Nokia Base Band 5 ( BB-5 ) 0 09-11-2008 02:59
Motorolla c117 show full network but call fail mcclinic Infinity-Box 10 07-26-2008 19:53
Motorolla c117 show full network but call fail mcclinic Motorola ODM 1 07-24-2008 17:43
T100 full signal but call fail.... help.. ?? TRABEL Samsung Hardware Repair 2 05-29-2006 11:03
Page generated in 0.17354 seconds with 9 queries
