Motorola v3 only light keyboard I have a motorola v3 which only light the keyboard it attempt to put in mode flash and it with himself I have not connected it to smart-moto and pst and I cannot flashing it some suggestion? Sorry my english. :p |
i have some probleme but now it solved i flach it by victor dongle;) |
insert phone in flash mood &flash it with PST |
i can´t put in mode flash, but i conect smart-moto give search: and give repair psd: Clip serial: xxxxxxxxxxx, version: 2.21, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 0.FF Reading flash id... 0x0090-0x0090 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 8365DFEE6FBF8F1 Security area saved to "S Blank Neptune LTE 8365DFEE6FBF8F1 (9).pds" Current phone does not correspond model selection |
Go to repair section (smart moto v1.12) mark in repair option "switch to 'Flash' tab on succes", next search (phone conectted to USB SMART CLIP) now you see Searching for phone... Found S Flash Neptune LTE, getting test interface ... interface not found. Switching to flash mode ...OK (not for first time but if don't remove cable and batery put it back and try again) if you see this screnn disconect phone (don't remove batery) and conect back to USB in your PC!, change to computer USB port (in phone connection) go to PC flash open full flash with shex format and write flash ( full flash you can download from www.motox.us , file R374_G_0E.42.09R_MXLP0001_GSMV3MXCIN01NA0F5_superf ile_MOTOX.shx is tested on my V3). THE END |
use smartmoto........repair pds then fullflash it................. |
use smartmoto........repair pds then fullflash it................. its work !!!!!!!!!!!! |
thanks :) |
are you sure that is not hardware fault??? i have repaired some phone with display module fault that make the same thing like your phone. |
did u use tp with ur smartmoto?........................................ .. |
