Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
02-18-2008, 04:47 | #1 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 315550 Status: Offline Thanks Meter: 110 | Need Advice on how to Flash roker E2!!! flash_key_press Boot module: Boot_G_00.02.05R.Sumatra MBM FLASH MODE. and Red Screen Display!!! Br... |
02-18-2008, 05:17 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 58
Member: 60668 Status: Offline Thanks Meter: 69 | press the side button, then connect to pc usb and flash, have encountered same trouble, my only problem is that, although the flashfile version are the same, my phone firmware bootloader is latest than my flashfile, and refuses to flash. |
02-18-2008, 05:28 | #3 (permalink) | |
Member: 315550 Status: Offline Thanks Meter: 110 | Quote:
anymore details sir? i cannot barely understand! | |
07-24-2008, 18:58 | #5 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 41
Member: 99756 Status: Offline Thanks Meter: 32 | 1. Firsr review the flash file. When you unzip the archive usually you will find only two files - one is .shx and one is .sbf file. First you will flash the .shx and then you will flash the .sbf. 2. Turn off your phone. Press the Voice Key + Red Key. You will get the primary bootloader screen. Now start hitting the voice key multiple times until the bootscreen text changes and you will see the secondary bootloader. 3. Connect your phone, open RSD Lite and flash your phone with the .shx file (in some firmwares there is only one .sbf file - choose it here) 4. After the flash is complete then you can turn your phone into the primary bootloader again and then flash it using RSD lite. Here you may need to follow additional instructions from the firmware post itself (like replacing some .smg files during the flash). However that is optional |
How to flash motorola e2 | razib250 | Motorola P2k | 0 | 12-13-2009 14:30 |
need advice on where to buy rocker dongle | ray_granville | Rocker Dongle (By Legija) | 2 | 04-24-2009 05:26 |
How to flash Roker E2 | east asia link | Motorola P2k | 1 | 11-10-2007 03:59 |
Help needed on how to flash W550i | changT | HWK | 4 | 11-07-2007 07:40 |
I need guidance on how to flash the T610 empty board with UFS | hooi76 | UFS2 + UFS3-Tornadoflasher | 3 | 04-23-2006 21:10 |
