Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
03-24-2008, 16:24 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 606592 Status: Offline Thanks Meter: 0 | Pressing "*" + "#" + "Power" but no display anything Try again i conect it with PC by USB and run "P2KTools VS", the program show my L6 "Connected Flash", i flash L6 with any firmware i have. But final result is zero, it no display anything although press power or "*" + "#" + "Power". Somebody please help me |
03-25-2008, 05:03 | #2 (permalink) |
Insane Poster Join Date: Mar 2007
Member: 469985 Status: Offline Thanks Meter: 6 | the reason why your programs froze is because you cannot run two p2k programs at the same time...or so i heard. you need to force bootloader mode then flash a compatible MP to force bootloader mode: remove your battery press and while holding down * and # keys replace the battery you should be in bootloader mode now... make sure that file you have is compatible to your phone (i.e. S/W version on file matches your phone) if you dont know, theres a possibility that it isnt compatible. im not sure which S/W version you have but if you post it, i'll see if i can link you... good luck and happy modding! |
03-25-2008, 16:18 | #3 (permalink) | |
Member: 606592 Status: Offline Thanks Meter: 0 | Quote:
When i plug cable USB to connect PC: -With "RSD Lite 3.9.1", the program display: Phone failed initial security verification checks. HAB error 0x35 Device Properties: IMEI/ESN/MEID: N / A Technology: N / A Software Version: N / A Flex Version: N / A Bootloader Version: v0x000200 DRM Version: N / A Phone Type: Engineering (F002000000003D3E091604110810) -With "P2KTools3", in "Flash Mode" the program display: Connected S Blank Neptune LTE I try flash with the firmware backup: - With "P2KTools3". My L6 display: SW Upgrade In Progress... Final, when flashing complete. Restart L6 but no happen, L6 display a blank screen startup no sound no light, don't understand. - With "RSD Lite 3.9.1". The program display: Warning: You are flashing the reflash file in to phone that appears to be blank. This only the valid use case if trying to recover a Neptune LTE/LTS based phone that has SECURITY errors. Do you want to proceed with flasing ? Choose YES When flashing complete, L6 reboot but no happen. Now i don't know what to do . SOMEBODY, Please help me. | |
03-25-2008, 16:44 | #4 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | Bootloader Version: v0x000200 <-- phone is in [S blank] mode, yoiu can try to reflash it with 1FF file, if that was not possible, then you need to flash with [image] file which contains BL inside. i think it will be hard to fix with only RSD, you need to flash image or write [Bootloader] with SC [Smart Clip] or [MSS II] and repair PDS area. BR Mansi |
03-25-2008, 18:20 | #5 (permalink) | |
I search and some where direct me make test point my L6 (very dangerous to remove the shell) and use "Motorola Repair Studio" to repair. Is it work? Help me Last edited by toanmai84; 03-25-2008 at 18:28. | |
03-25-2008, 18:31 | #6 (permalink) |
Member: 469985 Status: Offline Thanks Meter: 6 | as stated previous to your latest post...your phone is in "Blank mode" meaning you cannot see anything on your device screen but the computer does detect it. i still need your S/W version...without it there really isnt a way unless you can read the tag behind the battery door? not the imei number but there should be another alpha numeric sequence. i am going about this blind as i do not work with the L6 but i know for a fact that theres a way to find out the S/W version on the tag with L7s... do you see anything of this nature? |
03-26-2008, 05:09 | #7 (permalink) | |
AAUG1608AC/0Q2/0143 K64B4 S51OX0K3SH MADE IN SINGAPORE ---------------------------------- And serie in the shell IMEI:358018/00/999122/5 E17WGF3QM3 MQ3-4411/11 T675MD L6 FCC ID:IHDT6FW1 BD_ADDR:001700918F1D | |
03-26-2008, 12:30 | #8 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 287014 Status: Offline Thanks Meter: 28 | Try use p2k easy tool v3.9 Choose the model ( Must correct) Go to PDS tab, Select full repair PDS zone then hit do selected jod. Wait untill done. Unplug, go to bootloader mode (* + # + Power button) Connect Then Flash with RSDlite |
03-31-2008, 03:44 | #9 (permalink) |
Member: 469985 Status: Offline Thanks Meter: 6 | ok?...i cant make anything from those numbers/characters...usually L7's are easier to locate the S/W version as it states "S/W:08.C4.25R" for example. can anyone else help out??? i think he just needs the correct flash file...then again if its blank he needs to remove blank mode first...am i correct??? |
03-31-2008, 18:00 | #10 (permalink) |
Freak Poster Join Date: May 2003 Location: russia Age: 43
Member: 27947 Status: Offline Thanks Meter: 27 | try this one http://www.pontoprint.com.ua/L6(i)/R...AA02B_image.7z ,use rsd 3.9 or newer |
03-31-2008, 18:09 | #11 (permalink) |
Member: 27947 Status: Offline Thanks Meter: 27 | and also try any of this loaders before flashing image file the image is here http://moto-soft.net/sw/L6/R3511_G_0...A073_image.rar |
03-31-2008, 18:43 | #12 (permalink) |
Freak Poster Join Date: Sep 2003 Location: tunisia Age: 46
Member: 39239 Status: Offline Thanks Meter: 97 | repaire pds with smart clip then full flash with ******* pack you can download from: http://www.*****moto.com/forums/down...hp?do=cat&id=6 |
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery | eyestrain | Nokia Base Band 5 ( BB-5 ) | 1 | 06-21-2009 20:11 |
BF4.....phone is working good but no display | needi | BF, BG, TH, BHx Series | 10 | 12-28-2003 15:50 |
lcd ok but no display | garutech | Infineon C16X M51 & ARM7 M52 BASED | 5 | 09-19-2003 13:03 |
3310 ok, but no display if i choose to set date/time in menu | Migeni | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 07-23-2003 07:50 |
Alcatel 302 light ok but no display | spvaka | Alcatel TCL Hardware Repair | 3 | 06-26-2003 15:03 |
